Question about Kenmore 22642 Top Load Washer
Will not drain or spin
Will fill up with water and will aggitate but will not drain or spin
  • 5,911 Answers
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 18, 2009
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
You start the washer and the water will fill up to where it is suppose to but will not start to aggitate.The water will drain but the drum won't spin,than it will fill up again and it won't agitate...
Your drain hose is maybe too low and therefore gravity is draining out the washer OR the drain hose is too tight in the drain and a siphoning effect is happening.
Sep 22, 2010 | Hotpoint Washing Machines
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
Fills and drains but dosen't aggitate, spin. the water does drain out though
Check the lid switch it may not be activating the machine to agitate or spin after if fills with water.
Nov 08, 2009 | Maytag Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 22642 Top Load Washer Logo
221 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
