Question about Dryers
Whirlpool model WGD5300SQ dryer belt is off, roller is laying loose, is there a diagram?
  • 5,911 Answers
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Posted on Jul 18, 2009
What are causes for a Whirlpool cabrio dryer being very noisy when started
repairs on a home appliance should be performed by and experience appliance repair technician. a loose or missing blower wheel nut, belt support pulley or drum support rollers are common noises due to wear and tear.
Feb 09, 2017 | Whirlpool Dryers
My dryer heat but tub want turn i open the back and the belt was laying on the floor on the rt. side i would like to know if i would be able to replace it or not.
Hi again, Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200?searchedModel=86880800&blt=11
The belt is item 30 of this page:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200/00041279/00002?blt=06&prst=&shdMod=
The manual that will help you is here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Removal of the top is on page 19 / 14 printed of the pdf file
Removal of the toe panel is on page 20 / 15 printed if the pdf file
Removal of the front panel in on page 24 / 19 printed of the pdf file
The belt is installed with the ribs against the drom and the udler pulley / motor routing for the belt can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramH
Once you have the drum loose inspect the rear bottom drum rollers and idle pulley for any signs of wear. Flat spots or hard to turn = replace.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when moving..it should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under drum..you will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of belt....now once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
The pulley and brcket fell off it's position laying in the bottom of the dryer don't know how it goes ?
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belts. A replacement pulley can be ordered on line at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number is 691366 (if needed).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Whirlpool Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
How do you replace the drive belt on Whirlpool dryer?
What is the model number of the dryer.
Nov 14, 2008 | Dryers
Dryer belt broke and the wheel tying the belt to the motor somehow come loose and was laying on bottom of dryer when I went to replace the belt, need schematics to figure out how to put wheel back in...
Below the motor pulley is two sets of parallel slots and some notches running perpendicular to them. Look at the tensioner, the piece that is laying on its side. Notice opposite of the roller is a flat surface with flanges that line up to the holes below the motor pulley. Ok? Alright now we want to scoop the front into one of those notches and it will hold. Now the belt goes over this roller on the tensioner first pushing slightly away from the motor pulley causing enough slack to loop it around the motor pulley so it goes over then around. Have someone hold the drum and steady so you can reach in, ps make sure the dryer is unplugged.:)
Ok here is a site I use to get illustrated, Look it over and punch in your model so you can see roughly how to get er done. Notice item 53 this is on my dryer, use www.apdepot.com.
Sep 29, 2008 | Dryers
Whirlpool Dryer Model LER88620PW0
Go to repairclinic.com and click on the "Repair Help" link in the left column of the page. On the next page under the "Special Features" section there's a link entitled "Dryer Belt Diagrams". There are two diagrams listed under Whirpool (H and K). Since you stated that the tension pulley came loose in your dryer, I suspect you need to look at diagram "H". Diagram "K" has a tension spring and is fixed in place. I hope this helps you. Let me know if you have questions.
Sep 20, 2008 | Dryers
Dryers Logo
115 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
