Question about HP OfficeJet 6210 All-In-One InkJet Printer
Need information on how to remove and replace the upper half (ADR) on my officejet 6210 all in one
  • 2 more comments
  • Al LIPSKY Jul 18, 2009
    is there a manual available for me to purchase ?
    Can you e-mail a page or photo of the answer you sent?
  • Al LIPSKY Jul 19, 2009
    I am looking for a manual or pages from a manual that will SHOW ME how to remove thr top of an officejet 6210 all-in-one.
    y0u keep giving me the same answers, and i keep telling you i need more information.
    Where are the screws located?
    What are the locks?
    How are the locks opened?
    I need a drawing or photograph of the locations.
    So far i am just where i started with still no clue how to remove the top...
  • Al LIPSKY Jul 20, 2009
    i still do not have the way to get schematic of 6210, in order to see where and how to open locks
  • HP Master
  • 13,433 Answers
Hi
Here are my findings - service documentation
http://www.partshere.com/online/detail.asp?partno=Q5801A-manual
Parts for your machine
http://www.partshere.com/hppartslist/hpparts.asp?part=Q5801A
If your printer is not 6210 but for example 6210ix then look here for the correct model:
http://www.partshere.com/HPPartsList/hpallinone.asp?PIndex=4
Posted on Jul 19, 2009
  • 3,741 Answers
Yes its fitted on screws and inner clips called locks.its not very tough.the upper half will be connected by removable cables so after removing the screws and unlocking the locks.dont just lift the upper half quickly.slowly lift it and remove the cables from the circuit board slowly then lift the upper half/its simple and easy.only one proper screw driver and thin knife like material required to unlock the locks.that will help.
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Jul 18, 2009
  • charlymonty Jul 18, 2009
    for the service manual you will have to contact hp.com as if in stock they will provide you.as in that all the details of disassembly will be mentioned .but for the manual its possible you can get the manual at
    http://www.retrevo.com/s/HP-6210-Multifu...
    click the link directly and check out the manual.its free.for service manual from hp you will be charged as per the hp company.
    thanks.
    Please do rate the solution. Thank you for using
    fixya.keep updated. thanks
Can not uninstall officejet 6210
Go to control panel, select add & remove, check for the hp oj 6210 programmes, select remove,wait till remove, restart system, load the drivers..
Nov 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My HP Officejet 6210 has a message reading "Remove
Check that the HP all-in-one print queue is not paused (Windows) or stopped (Macintosh). If it is, choose the appropriate setting to resume printing. For more information about accessing the print queue, see the documentation that came with the operating system installed on your computer.
Check the USB cable. If you are using an older cable, it might not be working properly. Try connecting it to another product to see if the USB cable works. If you experience problems, the USB cable might need to be replaced. Also verify that the cable does not exceed 3 meters (9.8 feet) in length.
Mar 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam print cartridge stalled HP 6210 Officejet. It started all of a sudden and I can't fix it
Press "ON" till green lite appears. The display will indicate "Initializing..." and then lift upper half of the printer to access cartridges. Cartridges should move all the way to the right. If they don't, inspect the carriage belt for any obstructions.
Nov 06, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can I get parts to replace broken hinge? I have an HP Officejet 6210 All in One.
In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Dec 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
INSTALL PRINTER WITHOUT DISK HP OFFICEJET 6210
Here's a link to download the drivers for the 6210. If this helps, plz rate this as 'fixa'. If you have more questions leave a comment & I'll be happy to help. Thank you kindly.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-43586-1&lc=en&cc=us&dlc=en&product=421991&os=228
Feb 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
6210 printing bottom half
replace the cartridges.or the ink in the cartridges is getting blocked from the upper side.clean the cartridges.
Nov 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All in one scanning problem
just remove old driver from ADD REMOVE PROGRAMME AND THEN RE INSTALL YOUR PRINTER DRIVER AGAIN.
Jun 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Upper half line missing
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
manual here in link
sounds like the ink cartridges need to be aligned and cleaned there is an alignment button or in software for this
Apr 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
