5. Select the buzzer (if desired)
^ Press the "Buzzer" button to have a
tone beep at the end of the program.
Indicator light:
on = buzzer selected
off = buzzer not selected
To adjust the buzzer volume:
- turn the dryer on
- close the door
- select a program
- if the indicator is lit, press the
"Buzzer" button so the indicator light
goes out.
^ Press and hold the "Buzzer" button
until its indicator is lit and you hear
the desired volume and tone.
also if you need the manual for your machine your can get it directly from this link click here
http://www.retrevo.com/d/ds/progress?doc=508a0566a4fcfb2910e707b71d1fb918&u=1&rk=0.2030122370322724
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks again I await if you have any further reply
Rick
Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
