Question about Philips 50P8341 50" Rear Projection Television
The tv is mostly red
The redness is really bad there is basically no other color except red.
  • Philips Master
  • 8,617 Answers
Replace the CRT coolant, as the green and blue get congealed and that causes the red to become dominate. You can get the Phillips CRT coolant kit at the following link which contains the coolant and the instructions on CD.
http://www.tvrepairworld.com/
Posted on Jul 19, 2009
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Hello sir i am sasi from india pls tel me international color codes electrical wiring
Well colors can vary, but basically bare copper or green are grounds, white is the neutral wire (but it is powered in a switch loop, and when used in a switch loop it is taped with a piece of electrical tape to show it is powered). Black, red, blue, brown, and pretty much any other color except green and white can be a power wire (black red and blue are the most common colors used).
May 26, 2010 | General Electric GE ELECTRICAL TQD22200X2...
Why is the color red is gone
this is because of the color control circuit for the red , its most likely an IC that controls red has failed or even a bad resistor , capacitor , ect .. in that circuit will need replacing
Mar 06, 2009 | JVC AV-27530 27" TV
Mitsubishi Diamond Series T.V.
When a tv (Rear proyection) shows this coloration is the meanning that the red color is not there (the red color is generated by a red CRT). Now it can be really bad not having the tube working but before conclution make sure of this: (and if the red color gets back then the tube is ok)
  • is this condition the same in all inputs? or the picture looks ok with a different video source (VCR, DVD other)
  • are the menu letters same as the picture looks or are they fine?
If we cannot see any red color back with this testing, still chances that a technician find an electronic problem that make the tube to be off. so don't rush conclusions and get to the end to save the tv with out replacing the red tube, but if all was done and nothing then the tv needs the tube replacing.
Mar 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
The color on my dvd is red. The TV color is fine.
Bad chroma processor. Part of the video CPU. Service time...accordianman
Nov 24, 2007 | Philips HTS3400/37B System
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Red screen
Christ, why did you disturb the bias settings? Which stupid @#$% told you to that? The red color was most likely a blown Red Output Transistor, or something as simple as a bad CRT base. Now, I suggest that you switch off the TV, wait for a couple of hours, open the set, and very slowly and carefully pull the CRT PCB (along with sockets base. Then clean the CRT terminals (use a fine emery sheet.) Also check the base for dry (cold) solders. Replace the CRT board. Picture should be normal. If problem persits, then it is definitely the Red Output Transistor or associated components. Get a professional to have a look.
Aug 23, 2006 | RCA F27628 27" TV
All red picture now.
Sounds like a bad capacitor or drive signal on the red tube. Could be the red drive transistor, or a cold solder connection on the crt board
Aug 07, 2006 | Proscan PS36800HR 36" TV
Philips 50P8341 50" Rear Projection Television Logo
202 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
