No ac no cool air from my hvac the system is running but air from the vents is not cold
  • 614 Answers
Check outside breakers,float switch on inside unti might be stopped up drain. If not call service tech ask for free estimate. Russ
Posted on Jul 18, 2009
Air Con
no the pipes should not be cold and wet but if you just have stop using the aircon recently it will do that for a while till all the gas is out of the system so yes its sorta normal
Oct 02, 2008 | 2001 Chrysler PT Cruiser
Why my a/c unit wont blow hot air
Is it simply an AC or is it HVAC? If just AC it'll only cool but if HVAC and no hot is escaping through the vents towards your face then i'd call an engineer round to have a poke with a screwdriver...
Nov 05, 2014 | Heating & Cooling
What causes the ac to blow cold in the rear but warm air in the front?
These vehicles came with 2 types of ac controls.
The vacuum control system uses vacuum to actuate the vents and ducting from hot to cold. A lot of times the HVAC vacuum line in the engine bay (black hard plastic) is either broken or disconnected from its vacuum source.
The electronic vent control: does everything at the control knob via vent actuators and the control panel itself. With this one it could be any of the components. You would have to locate them and verify operation by moving temp/vent selector.
May 08, 2014 | 1997 Ford Expedition
AC blows hot air out the front vents no matter the setting. It is winter so it is not too bad. The back vents blow cool air but not cold.
Getting your system recharged at a dealership would be recommended but only hot air coming through the front could be an hvac problem, make sure that all your vacuum lines that run to your system are not crushed or unplugged, they will be located in the engine bay of your vehicle.
Jan 29, 2013 | 2001 Toyota Sequoia
The a/c dont working only heater
If the compressor is running and one of the ac lines is cold, you probably have a blend door stuck or faulty in the HVAC box under the dash. The blend doors direct air thru the heater core and evaporator core as well as thru the vents.
Jul 27, 2012 | 2000 GMC Jimmy
Ac just been charged and it still blowshot air
{: ) If the a/c compressor is working and the low side pipes are cool to touch, well and good, since you have a ready source for cool air. With a normally functioning HVAC controls, the front vents should blow cold when adjusted to cold settings, on recirculate, and on face mode. Otherwise you have an air distribution malfunction. Confirm first if the low side pipes are actually cooling.
If no cool air comes out, ( or maybe it's coming out from another vent) then you have a problem with one of your HVAC actuators. You can confirm this by adjusting the knobs or buttons to every position and check if the air distribution is shifting as you intended it to be. A scan tool can pinpoint which of these actuators are stuck or not responding. It could even be the HVAC controller module itself.
Aug 28, 2011 | 2004 Chevrolet Suburban
05 ford ranger 3.0......if I put my thermostat on cold...the vent blows hot air..on max ac..its cold air..makes no sense right....help
Cold air like, really cold or just cool. Sounds like your hot/cold blend door motor has perhaps failed with the blend door in the semi hot position. Blend door motor failure is very common on the Ford truck HVAC systems. Is is located behind the glovebox on top of the HVAC housing assembly.
May 19, 2011 | 2005 Ford Ranger
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
