Samsung PN59D8000FFXZA - PN59D8000 59 3D 1080p Plasma TV - Logo
i
imtiaz Posted on Sep 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my samsung pn59d8000 no picture and sound but a red blinking light when I power it on . Is it power supply or something else
Meir
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 14, 2016
Meir
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
398
Points
8
Seems like a power supply issue, good luck.
Myra Rod
Level 2:
Habit-Forming:
New Friend:
  • Expert 81 Answers
Myra Rod
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
81
Questions
Helped
6135
Points
428
For Tech Support you can call on 1-877-778-89-69 to the tech expert team available here.
http://resolit.us/Samsung-Support.html
1helpful
I have Samsung 42 inches plasma TV model-Ps42c430a1 and Sr - 189938YB400505D it's red light blinking 6 times and tv create clicking sound no picture & sound who to fix it ?
I suggest an authorised Samsung repair agent, (a list can be found on the Samsung web site), otherwise you will get panel changers and not engineers that repair to component level.
One common culprit of this issue power supply issue, caused by a faulty power supply unit or the TV not receiving enough power, caused by faulty electrolytic capacitors on the Power Supply board.
Samsung model un46eh5300fxza no sound, no picture, no back lights. When turned on red light blinks 5 times but nothing happens.
1. disconnect the cable between the power supply & the main board, if no back light, replace the defective back lights LED strips inside of the panel.
2. If the back light are light up, i will try a new main board.
Model # unh6350A samsung smart tv ,no picture no sound with blinking red light .
It sounds like the main board has failed however there is also a possibility that the power supply is the cause; there are capacitors on the power supply that can cause a lot of issues like this
Why are picture and sound gone?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
I was wondering if someone could help me find which board could be bad on a Samsung PN59D8000FFXZA plasma TV.
look on the power supply board for burned parts. The board that controls the back light may have some burned parts as well.
I have the Samsung model: LN46E550F6FXZA, I can hear it power on, the red light on the front blinks 5 times then goes off. There is no sound or picture.
You will need to have it repaired, looks like the inverter board is broken. Google Samsung tv blinks 5 times, there's tons of threads.
1helpful
2answers
5 blinking red lights when turned on
When you remove the bad check for bulged electrolytic caps, that need change, or change out the power supply.
2answers
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
