Lost power , breakers were tripped when turned back on the check light came on
SOURCE: Circut Breaker trips
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
SOURCE: Refrigerator turned off and won't turn back on
Is the light on inside? If yes then you need a new contrl board located on the back wallll of the unit. It has changed 6 different times from when you bought the fridge. That is six different issues they where trying to improve or remedy on the prior boards. If the light is not on plug in something else to make sure the outlet is powered up, and inspect the power cord for breaks. Hope this helps.
SOURCE: Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
SOURCE: dometic RM2862 will not come on at all, no blown
I have the same problem Have replaced the power Modular still Refrig light or anything styill doesn't work. Anyone have any suggestions?
