Question about Amana Quiet Zone 12M12TA Air Conditioner
Noisy Amana Quiet Zone air conditioner
My air conditioner works (well, it blows out cool air...), but it is really loud and the case gets hot. This problem just cropped up a few days ago. It is loud only when the AC is on; the fan works fine.
  • mackenzie_a_ Jul 18, 2009
    Fixed it: the trim was loose on the upper left hand side of the unit (near the control panel). I put a clamp on it, and it runs nice and quiet now :-)
  • mackenzie_a_ Jul 20, 2009
    I managed to make the noise go away by tightening down a loose piece of trim. It worked fine for about 12 hours, but then all of a sudden it stopped cooling. The compressor won't kick in at all, even if I set the temperature really low. It made a "click, hum" noise like it was trying to start, but it never did. Any ideas?
  • 614 Answers
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Posted on Jul 19, 2009
Not cool enough
What is the temp of the air copming out of it at this time depending on the room temp it shuld be about 15-20 degrees cooler than room temp
Jul 24, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 26, 2010 | Amana Comfort Zone 12M32PBEH Air...
Water does not drain from my Amana quiet zone AC. It builds up inside, then causes rusty looking sedement to blow into my house. How/where is the water supposed to drain to the outside? Thank you, Bobbi
If this is a window unit it has to tilt a little to the back(outside) for the water to drain off the bottom back side. I am suspecting the unit is setting tilted toward the room a little. Look at that first. Hope I was of help to you!! Good luck!!
Nov 22, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone air conditioner 12m12ta
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Jul 17, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Problems with Amana Quiet Zone 12M12TA, kicks off after short runtime, but other times runs for an hour cooling OK. Hear a clicking when it shuts down? Could not find a fuse ot relay?
Does it run longer when it's cooler outside like at night? If it is, it could be shutting down on high pressure or temperature caused by dirty condenser or you could have an overload in the compressor wire box that is weak or has a loose connection. Check the condensor coil to see if its dirty and see if it has an overload on the compressor.
Jul 11, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Not heating
Yes, the reversing valve has a separate coil. some energize on cool mode, some on heat mode. Has the thermostat been replaced? I find this a common mistake.
Nov 03, 2007 | Amana Comfort Zone 18M33PCEH Air...
Amana Quiet Zone 12M12TA Air Conditioner Logo
348 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
