Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Was idiling in the street when i heard a loud pop, and now it turns and turns, but won't fire and it feels as if something is vibrating in the engine itself. HELP!!!!!!
  • Wesley Golden
    Wesley Golden May 11, 2010
    Have you checked if there was any compression,
    pull the spark plug and spin the engine either with a gauge hooked up or with
    your finger just to see if you have any compression. FYI make sure the spark plug wire is either grounded or pulled away from your hand before doing this we don't want any suprises. If there are no visible
    cracks or holes in the engine case you may have cracked the camshaft. What type
    of engine is it?
  • 130 Answers
Take sparkplug out stick a screwdriver in hold
to see if piston moves when you pull rope if not though a rod if it does move the coil is could be your problem it also could be the valve check clearence
Posted on Jul 18, 2009
When I turn into a parking space or onto a street it sounds like something clicking or vibrating even when i push my clutch in
Most clicking/popping noises when turning indicate a bad ball joint in the front axle. The CV joint has a boot over it that will eventually rip, causing the grease inside to be slung out. Dirt and moisture will get in there and cause the smooth joint to pop when under stress, like turning.
Mar 19, 2014 | 1999 Honda CR-V
Battery is charged, Starter Whines and is turning but bike won't fire off, 2009 Street Glide
is your engine turning over, if it is, pull your spark plugs and clean them. this happens on my 98 Heritage Softail Classic. It sounds funny but from long warm ups with choke pulled they get carbon build up and this keeps the plug from firing. If your motor is not turning over then you Bendix gear is out on your starter.
Feb 12, 2013 | 2009 Harley Davidson FLHX Street Glide
2005 impala steering vibrations
Probably front wheel drive so it could be A strut needs replacing or tie rods or control arm bushings they are all major repairs unless you know a good cheap mechanic
Aug 20, 2009 | 2005 Chevrolet Impala
Engine turns and turns but does not fire
you will have to check the coil for fire.
sound like coil went bad
Jul 18, 2009 | Garden
Appeared to have a low battery when starting my bike, but it turned on. Rode about 1 1/2 miles when it hesitated twice and then i heard a loud pop, sounded like a backfire. The bike turned off and i had no...
So is the battery...ignition needs "X" amount of Volts to run the ignition, the BANG you heard was the engine pre-igniting a fuel mixture in the combustion chamber - because the ignition didn't have enough juice to fire the plug...but the HEAT of the engine DID!
Replace the battery with one from WalMart and Ride!
Good Luck
Jun 23, 2009 | 2001 Suzuki VL 1500 Intruder LC
Heard loud bang my volkswagogan passat 1.9 tdi 2003 reg.
it is probally the hose from the turbo outlet that has split,they are dead common.remove the undertray and look and feel the pipe that drops down from the turbo and goes to the connecting pipe that runs along the front of the car.
Feb 19, 2009 | 2003 Volkswagen Passat
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
349 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
