Rheem Richmond 40 Gal Nat Gas 6 Year Power Direct Vent Water Heater Logo
mary kram Posted on Sep 14, 2016
Richmond 40 gal water heater from 2003 gurgles loudly when refilling, is that normal
teester49
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 19, 2016
teester49
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1731
Points
5
I'm not sure what you mean by "gurgles when refilling." If you mean that it is making noise when heating the water, that is usually a sign that sediment has built up in the bottom of the tank. This results in the surface of the tank bottom to overheat and the sound you hear is the water flashing to steam. This usually results in tank failure as the glass lining will crack an the tank will rust out. If it's not too late you could drain and flush the tank to try to remove the sediment but if has hardened to a solid mass it won't come out.
  • robert Sep 21, 2016
    the short answer is at 13 years it has run its life's course. gurgling is not normal. get a new one before your have to get a new one.
BROKEN Pilot TUBING STUCK IN GAS VALVE RICHMOND WATER HEATER 40 GAL
There should be brass ring on the end of the pipe that makes the joint when the nut it tightened to make the joint . Or the end of the tube my be flared .
My hot water just stopped running from hot side but cold still runs all sinks so what happen
It is probable the cold water comes in from the outside pipe so will be unaffected by anything that happens to your boiler/water heater. The boiler/ Water heater must have an issue, the problem is not a water cut I THINK.
8helpful
2answers
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
