Question about Acer Computers & Internet
Problems with an external Hardisk
I have an Acer 80GB external hard disk which is approx 3-4 years old. I have never had any problems until recently, however in the last couple of days, when I connect it to the computer, the light is on constantly and when I try to access it I can't. I have tried formatting it, but but it does not seem to go any further than trying to go the formatting window. Any ideas I have tried deleting but that does not work either.
Thanks.
Andrew
  • 44 Answers
Hi Andrew,
I can suggest a few things but does not sound good. I am assuming you are on a PC-Windows.
1. Try the drive on another computer. If it acts the same, you have ruled out a configuration or driver issue conflict on your computer and you can focus on the drive. If it works on another computer, then you would need to go into your original computers device manager to see what errors you are getting.
2. If the drive does not work elsewhere then about the only thing you can do is replace the cable... assuming it is replaceable.
3. Not that this is a fix but I have had drives that failed to work properly and, after being put in the refrigerator for an hour or so, I could get to spin up long enough to get files off them before they got hot again and stop working. As I say, this will not fix anything but it may confirm that it is defective. Don't laugh but why this sometimes works is heat sensitive IC's, poor solder connections or some disk alignment mech. problems that stop the drive from working at or above room temp.
If the drive is history, probably more cost effective to just replace it unless it is under warranty.
Hope this helps!
Posted on Jul 21, 2009
How much is the price of 80 gb hard disk of a acer aspire 4315 loptap
You could pick one up for approx $70 Try Google the Internet for a 80Gb hard drive, you will get a price comparison form various suppliers.
Sep 09, 2011 | Acer Computers & Internet
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
I have an ide hardisk and it has an XP operating system but when i used it my new asus board the hardisk is detected but it cannot load the windows and its just always keep on restarting. does my 512 ddr2...
If you are attempting to boot from a hard disk that was from another computer you will have problems because of architectural differences. You would need to place it into an identical pc build. You can install a new operating system then read the disk as an external or secondary drive, or do a new install from CD onto the same disk.
Sep 12, 2010 | ASUS M2N68-AM SE2 Motherboard
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
I have an Acer 5720 laptop with 80GB hard drive thats full.
To remove temp files and old compressed files run Disk Cleanup to free up disk space.
Click on My Computer then right click on the C drive and then Disk cleanup, if you have never done this before it will take a long time to complete. Then repeat this for the D drive.
Disk Cleanup and Defrag should be carried out approx. once every month to keep the computer operating at its best.
Aug 29, 2009 | Acer Computers & Internet
Thinkpad T42 Hard Disk problem
Hello.
It seems the hard disk size will max out at 80GB with a 5,400 RPM speed according to IBM.
Im sorry to say that this means that it will not support a 120Gb hard drive.
Regards...
/Tech5508
Feb 14, 2009 | IBM ThinkPad T42 Notebook
What hard drive can I upgrade my old 450ROG with?
Sure you can. You can get your hdd on ebay at very reasonable prices and new.
Here you have one of 80GB new at $ 60 free shipping
http://cgi.ebay.com/New-Hitachi-Laptop-Notebook-80GB-2-5-Hard-Drive-IDE_W0QQitemZ320309086044QQcmdZViewItem?hash=item320309086044&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1308&_trksid=p3286.c0.m14
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
