Question about General Electric WJRR4170GWW Top Load Washer
Where is the ge washer motor brake - General Electric WJRR4170GWW Top Load Washer
  • 1,543 Answers
On older models, it is part of the transmission assembly, but on newer models, it is an electrical brake within the motor.
Posted on Jul 18, 2009
Slow spin
http://www.youtube.com/watch?v=YZKqpoVX3t4
watch this video to reset the computer board,if it doesn't help you have to replace the motor,this is not that good of a washer,whirlpool duet is a good washer but that's my choice
9 flashes - The brake resistor failed. This code will limit the motor to 50 rpms. Try clearing the code and if the code comes back replace the motor.
Jun 13, 2013 | GE Washer Motor - WH20X10058
The washer is powering up but the motor is not spinning as strong as it should it is moving back and forth but very slowly, water is filling up and draining but the cloths is still wet and did not wash,...
Sounds like you may need a motor. If the electronic brake fails it will cause the washer to slow down. there is a led on the board in the motor. See if you can find it and count the number of flashes. 9 flashes is bad brake.
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Violent vibration of washer machine
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Mar 02, 2011 | GE WJSR4160DWW Top Load Washer
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
Machine wont spin out items are full of water
Take the belt off and run the washer to see if the motor will turn without a load.
Newer style GE - long history of transmission/brake issues with these. Best course of action is explained at this link:
http://www.big-boys.com/articles/gernadewash.html
Mar 31, 2010 | GE WBSR3140DW Top Load Washer
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Jun 07, 2009 | GE WJSR4160DWW Top Load Washer
GE washer wssr2070v1 will not spin.
If you hear the motor running but nothing is happening then check the belt on the bottom of the machine and the brake to make sure that the belt is not broken or stretched and also that the brake is not holding the drum
May 23, 2009 | General Electric WBSR3000G Top Load Washer
G.E. spacemaker washer will not spin
possible faulty motor. Regards Advisor
Aug 22, 2007 | GE WSKS2060WWH Top Load Washer
GE Spacemaker No Spin
the washer has carbon brushes on the motor if these are low the drum will not spin it needs these carbons to make contact with the motor
Aug 12, 2007 | GE WSKS2060WWH Top Load Washer
General Electric WJRR4170GWW Top Load Washer Logo
368 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
