Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
My stainless silverware and plastic serving spoons, well just about everything has a cloudy, gritty film on them. What can I do?
  • erica graber May 11, 2010
    do you have heat? do you use rinse aid? put a cup on the top rack upright and let unit wash for about 3-5 minutes does the cup fill up with water? let me know
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is your water actually. there is a new product out at www.dishwasherfilter.com that filters out the hard minerals that leave this residue. it is very afforable(like 70 bucks) and works amazing guaranteed. you will love the way your dishes look after the very first load.
Posted on Aug 09, 2009
    President:
  • 1,273 Answers
In addition to the clarification posted by egraber (above), try this....Use the least amount of detergent that you can stand. We usually equate more with better, but not so in this case. The detergent is a bit abrasive, and, over a period of time, will leave scratches and deposits on your dishes, flatware and glasses. If you load the cup like egraber recommends, place detergent in the dispenser. When you remove the cup, test the temp of the water as he recommends, then slowly pour the water off, and check for sediment/soap residue.
Regards, --W/D--
Posted on Jul 18, 2009
Our Maytag MDB9100AWB is 5 years old. Have had repairman out several times. Problem is a light cloudy scum on everything. He has replaced several items, has had us clean parts and fixtures, etc and even...
There are three typical causes of chronic cloudiness on glassware/dishes.
  1. The incoming water may be too hot. Make sure the water is at or below 140 degrees F.
  2. Test to see if cloudiness is removable by hand cleaning or soaking for 5 minutes in white vinegar. If it is removable, it's due to hard water. Use a good quality detergent, and match the amount of detergent used to the water hardness and use a rinse aid. (Some low quality detergents clean poorly and leave a film.)
  3. Glassware may be etched, due to too much detergent, too high water temperature, or pre-washing. Etching is not reversible, so it's important to correct the problem promptly.
Hopefully these hints will help you to home in on the problem.
Dec 27, 2010 | Maytag MDB9100A Dishwasher
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
I am getting a white film on my plastic glasses and plastic spoons. Why?
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Sep 16, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Lately my dishes in the diswasher (and silverware) come out cloud
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 27, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Hard build up of cloudy film on glasses and silverware ruined.
Can you try using vinegar on one of the silverware pieces for me and let me know if that helps? Sounds like it may be a hard water issue.
Sep 26, 2017 | Kenmore Dishwashers
Cloudy film left on glassware *rinse aid cup
make sure b4 you start the machine run the water until it is hot then start the machine. let me know if it works by sending me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
Have Whirlpool dishwasher #GU2300xtsqo. White
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 16, 2010 | Whirlpool GU2300XTS 24 in Builtin...
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
166 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
