Question about Poulan Pro 22" Self Propelled High Wheel Mower
How dow install blade adaptor on my Poulan Pro?
  • 389 Answers
Remove the old one and slide the new one back in its place lining up the built in key with the slot in your engine crankshaft. A bit of advice: put some never-seize on it before you install it. Will make it a lot easier if you should have to remove it in the future
Posted on Sep 30, 2009
My poulan pro lawnmower blades are not cutting when running
Are your blades installed up side down?
Is the blade drive belt installed properly or are the blades turning backwards? Is the belt too loose and slipping?
Are the blades dull and need sharpening?.
Oct 04, 2014 | Garden
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
What size blade duds it take
You can measure the length of the blade or take it off and go to a store and get a mulching blade it doesn't have to be a Poulan Pro
blade a generic mulching blade of the same size will work and be cheaper. Tractor supply handles a lot of different types of blades.
Jun 17, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
How do I remove the blade adapter from a Poulan Pro 22" self propelled mower
The blade adapter is a "slip fit" on the crankshaft and is held on by the blade retaining bolt. However, due to rust, etc. they can become difficult to remove. You may try penetrating oil to help loosen the rust.
We generally use an air tool to remove stubborn adapters but you have to exercise caution so as not to put undo stress on the crankshaft. In some rare instances they have to be "cut off".
Feb 20, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Looking for 22" blade for a Poulan - PO550N22SH - PN 961120080 - where can I buy a lawnmower blade? Can find the number on the internet, but can't find a dealer that sells this product.
Your Poulan Pro mower is made by American Yard Products and the parts will interchange directly with Craftsman 22" mowers. You should be able to find a replacement at your local Sears store. All of these part #s are also 22" AYP blades:
AYP #'s
406713
192682
157101
335256
114886
141114
Rotary #15-6236
Oregon #
95-043
95-042
95-055
95-023
95-021
95-602
The different #'s should all fit. Some of them are bagging style blades (high lift) while others are designed to mulch.
Online sources will include www.searspartsdirect.com and www.amazon.com
Good Luck!
Aug 25, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where are the oil drain plugs for a poulan pro 550 model
under the deck above the blade. It is probably a square head pipe plug
Oct 17, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 22" Self Propelled High Wheel Mower Logo
98 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
