Swamp cooler starts up automatically after power outage
We just bought a house with a swamp cooler. Don't know about the make of the cooler, but has a MasterStat thermostat. It runs fine, however, if we have a power fail, when the power is restored, the swamp cooler starts up, even it had been off prior to the loss of power. The thermostat has automatic and manual settings, with a temperature dial. The on-off control is a push button toggle, not a 2 position switch. I can duplicate the problem by switching off the power to the house. I've tested it with the control in auto and manual, with the unit off. No matter what, it starts up when the power is restored. Do we need a new thermostat or is this some kind of electrical problem? Thanks.
  • npread Aug 04, 2009
    Haven't tried disconnecting the tstat yet. When I was last there, I had pulled the front off, which removed the button controls, and found 4 fine wires that apparently match up to 4 pins on that front panel. Didn't think to try the power test without the front of the tstat. I can try that next time I am in the house. I'll be sure to have an ohmmeter on hand and will also verity the wiring behind the tstat.
  • James Stopp
    James Stopp May 11, 2010
    If you disconnest tstat and trun off power does it have the same problem. Russ
    Champion:
  • 233 Answers
Generally ther thermostat is the "brain" of the system, check the wiring diagram (if there is one) or the wiring and see if the on off swtch is inseries or parallell to the thermostat, (should usually be in series if it is I would say that the on off switch is the culprit. you cna verify with an ohmmeter to see if it is staying in the closed position.
Posted on Jul 19, 2009
  • cwithnell Apr 28, 2011
    If the power is on to the unit then it is summer and the cooler should run when the thermostat tells it to. After a power outage the temperature usually rises inside the house, therefore the cooling is required to run. It is designed to turn on automatically after a power outage. If you don't want it to turn on then turn off the power switch. If the system was not installed with a power switch (depends on local codes but most require them) then turn off the circuit breaker.
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
We have a marquis swamp cooler don't know how old
Your blower motor, or pump motor, or belt has failed.
Jun 21, 2013 | Heating & Cooling
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
Remove the front and rear panels off of a MasterCool P12
Lift yhe panel and pull out at bottom. The ones that come out usually have hand slots
Jun 09, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
