All of the instructions can also be found at
www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
