Question about IBM Infoprint 6500 Matrix Printer
PRINTING ON A BLACK BACK PAPER
HOW CAN I MAKE MY IBM INFORPRINT MATRIX PRINTER,PRINT ON A BLACK BACK PAPER FED INTO IT.
  • IBM Master
  • 1,113 Answers
DYE YOUR RIBBON WHITE SPORT!
White ink the ribbon, should do the job, never seen anything comercially for it.
Posted on Nov 19, 2007
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
IBM 6400 Matrix Printer is printing twice over a previous line it seem on to happen once or twice per page of text there seems to be no issue with the tractor feed no drag on the paper source and the test...
Might be your gap is set to high. try moving the right lever from A to B for example and see if it clears it out. Also might be your parallelism, you will find to hex screws on the right and left of the platen assy that u can adjust. This will balance out the shuttle if one side is printing to light and another is printing to dark. Rory 708-597-4222
Oct 07, 2011 | IBM 6400 Matrix Printer
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the...
This is a SNIP of a rather LONG FIX:
Found here:
http://forums.windrivers.com/showthread.php?7080-RESOLVED-Okidata-Microline-184-Turbo
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
AND THERE IS THIS:
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Anthony
Dec 25, 2017 | OKI MICROLINE 520 Matrix Printer
Hello I have an IBM 6400 printer at work. It prints documents, but every now and then it will print the documents with a white streak running down the paper, like it doesn't print in that spot. I tried...
Hi there, I hope you haven't throw away the printer.. :)
i face similar problem.. its solve by tightening the ribbon latch screw that secure the latch to the ribbon motor.
Feb 02, 2011 | IBM 6400 Matrix Printer
Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Jan 23, 2009 | IBM 4247 A00 Matrix Printer
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
IBM 4232 Printer Problems
in the PRINTER SETUP menu there will be FORMS DEVICE
select and set
Continuous Forms — F1 or F2
Dimensions
Forms Min Max
Width 3in - 15in
Length 3in - 14in
Nov 05, 2008 | IBM 4232 Matrix Printer
IBM 4234 dot matrix
Sounds like the configured paper sized does not match the actual paper page height. So that when it does Top Of Form paper movement the paper stops slightly too low. Doing several form feeds should confirm this. If this is it then reconfigure the paper size to match the paper. Also measure to paper to see if it matches what you want it to be.
Mar 04, 2008 | IBM 4232 Matrix Printer
Black back media
Hi Daniel,
This occurs because of the light sensor perper out sensor. A quick fix is locate the sensor on the left hand side of the paper path and then temporarily tape a piece of white paper over it. You just need to make sure that you keep an eye on the printer as it will not report paper out, now.
Aido
Nov 19, 2007 | IBM Infoprint 6500 Matrix Printer
Forms jam on IBM 4232
there are 2 paper sensors in the 4232 printer. the first is the most obvious and is a large black sensor found at the front of the printer and the paper is fed through it. the next sensor is on the printhead carriage assembly. its rather small and can be easy over seen. the sensor is just to the right of the printhead assembly. Clean both sensors and make sure they are properly locked into their sensor homes and this should take care of your problems. If not then it might be time to replace those sensors.
Aug 27, 2007 | IBM 4232 Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
104 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
