Question about Gaggia Titanium Espresso Machine
My gaggia titanium has Water leaking from inside machine right side near steam wand pipe when I warm machine and make coffee also steam wand stopped working no steam
Water leaking after warming up and making a coffee from top of pipe inside right, the flexi pipe that connects to steam wand
SOURCE:
  • 2042 Answers
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Posted on Feb 03, 2008
EsWorld
  • 1618 Answers
SOURCE: Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Posted on Jul 15, 2009
EsWorld
  • 1618 Answers
SOURCE: no hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Posted on Nov 29, 2009
  • 1089 Answers
SOURCE: Gaggia Titanium coffee maker leaking water
What color is the steam manifold? It is located under the black cover with the trough in back under the white tube. If its white or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand. But its going to have to be replaced.
If it is silver you probably have O-rings that need to be replaced. I would use the black O-rings, not the red. The red ones are a little smaller and can leak.
Posted on Dec 01, 2009
  • 55 Answers
SOURCE: Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Posted on Dec 17, 2009
Have water leaking out of bottom, clear water. Will brew coffee but liquid is reduced by amount coming out of bottom of the unit. Have decalcified and use only RO water. Any ideas?
Is the water hot or cold? If cold you need to check all pipes and their couplings from the water tank to the boiler. If the water is hot, then check all pipes and couplings from boiler to brew unit and steam wand.
Aug 09, 2011 | Gaggia Titanium Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Hi, the hot water outletpipe( i don`t know how to say it in english) keeps leaking water. If the machine is heating up, tehe pipe allready starts leaking and keeps doing it. The machine is only 8 months...
Do you mean the "steam wand" ? The pipe you would use to steam milk?
That sounds like the steam valve needs replacing or rebuilding. If the machine is only 8 months old it is still under warranty. You should contact the store where you bought it or contact Gaggia service center in your country.
Sep 21, 2010 | Gaggia Titanium Espresso Machine
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium - lack of water/steam!
I have a Gaggia Titanium and the steam valve is leaking can I get repair parts for it
Mar 12, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
No hot water or steam from wand.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium leaking underneath
Andy15 - Thanks - you encouraged me to do this myself.   I made a video as I did my repair.  The video making was more work than the replacement of the steam valvle.   Please check out my video if you have have to make the same repair.   Also - the technical support from WholeLatteLove was great.  http://www.youtube.com/watch?v=8UgVBoFd5aE
Nov 30, 2007 | Gaggia Titanium Espresso Machine
Gaggia titanium leaking water underneath
i had this same problem. the solution is simple if you are a little bit handy.
there is a bad valve inside. i called Whole Latte Love where i bought the machine and ordered a Steam Valve complete - Compact Frame
its part number GA-%0345.R and two O-Rings
the valve that comes with the machine is plastic and the new one is a brushed metal casing. my guess it will last for 10 years!
two screws on the back and the machine is open
near the front, by the steam wand, with a hose attached coming from the heater, is the valve, attached to the knob on the side
two more screws and the valve wrapped in a plastic housing comes out.
open the plastic housing, remove the insulated hose to the steam wand and the water/steam plastic hose that comes in. replace the valve, hook up the two hoses, but back in housing and you're done. attach back to knob on the outside, put back together and in 30 minutes, the Titanium is like new. no leaks.
it sounds daunting but is pretty easy and beats sending the machine back for repair. i can't go a morning let alone a month without coffee from my Gaggia. once repaired, the coffee is hotter too.
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
258 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
