Question about Ovens
Replace broiler heating element Whirlpool builtin oven
  • 530 Answers
Do you want to know how to replace it? turn the power off first. open the door to the oven usually there are 2 screws that go to the broiler. unscrew them pull the heating element out remove the wires, make sure you pull them out far enough or you will loose them in the back of the oven. plug the new one in screw in the screws and you are good to go. let me know if this helps
Posted on Jul 18, 2009
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
The broiler works but the oven won't bake. i think the bottom heating element needs to be replaced
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 02, 2011 | Whirlpool Ovens
Broiler element does not heat on ge jkp15bow2bb
ck the element and witing to control / then go to the control . elements are very common .. mm
Jul 14, 2010 | GE JKP15 Electric Single Oven
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
I recently put my oven through the self clean cycle then the next day neither the oven element or the broiler element will heat up. There is power to the control panel.
Probably the Thermal Overload Sensor burned out from the excessive heat during the cleaning cycle. It Is located on back side of oven.
Sep 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
239 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
