Question about Autotek MX3000.1 Car Audio Amplifier
Hi! I have a Autotek Mean machine 1400 1D. It doesnt power-up exeptfor the ble LED lights. The "POWER" and "PROTECT" doesnt light-up at all. What could be the problem? I just bought it and it is supposed to just be a "showroom-sample".
Could be the power supply.
Posted on Jul 19, 2009
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
It Will not turn on
maybe ur need a capacitor cuz ur prob over loading ur power supply
Feb 22, 2010 | DHD NTX-2004 Car Audio Amplifier
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
Tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Amplifer
recheck your ground make sure it has a good connection most of the time this is what it is
Feb 11, 2008 | Autotek SS290.2 Car Audio Amplifier
Autotek amp
You got riped off if i were you i would go and get my money back because an amp like that cost around 399 to 499 dolars
Jan 24, 2008 | Autotek MX800.4 Car Audio Amplifier
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Autotek mean machine 200xi
fuse blown maybe? check the fuse(s) on the amp, and also on your car's dash for audio or acc maybe. And check the bubble on your battery.
Jan 30, 2007 | Autotek MX1500.1 Car Audio Amplifier
Autotek mx1500.1
i am a master audio amp repairman i am working on an mean machine mx 1500.1 the RCA inputs wer just worn out on mine,
but your problem is much worse your power supply is gone, all mean machine`s are CLASS X mind you NOT CLASS D basicly all that means is that the audio feads directly into one big power supply unit instead of having both an input and output stage.I recomend you find a web site or audio shop with a phone number
for the autotek corp. and have it sent in..DO NOT WORK YOURSELF
Autotek MX3000.1 Car Audio Amplifier Logo
272 people viewed this question
Top Autotek Car Audio & Video Experts
Professor_V
Professor_V
Tom Chichester
jeffrey richard
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
