Question about Samsung VP-W90U Camcorder
Playback of 8mm tape
Shows on tv at double speed.
  • 76 Answers
SOURCE: video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
Posted on May 21, 2007
0 characters
1 Points
Playback 8mm camcorder tape fuzzy
8 mm and the newer super 8 mm video tapes are different. You can't use super 8 mm in old player. And old tapes won't play well in new super 8 mm players. Like Sony!
Nov 04, 2013 | Video Cameras
I have a Ge camcorder 8mm model Cg814. When powered on and placed in the edit/playback mode for reviewing, I can hear the sound, but there is no picture in the viewfinder. There is also no picture on the...
It sounds like it could be: (1) Video track on the tape might be messed up. Or (2) The heads on the camera may be dirty. Or, (3) It may be dirty battery connection. (Most likely, it's dirty heads.)
Solutions: (1) Try playback with a different tape that you know is good. Still nothing?? (2) Run a head cleaner specific to your camera, for about 20 seconds. Remove head cleaner and wait 10 to 15 minutes. Put tape back in and try playback again. This will probably solve it.
Another thing to try.. (3) Turn camera OFF. Remove the battery, wipe off the connectors on both the battery and the camera with a clean cloth. Return battery to the camera.Try playback again.
If these steps don't solve the playback problem, you will probably need a camera repair person.
May 16, 2011 | Video Cameras
Cannot play them
Oh boy the 8mm tape will work in a hi 8 playback but the resolution will be just 8mm
Just the same if you have hi 8mm tapes you can record on then with regular 8mm cameras.
Jul 26, 2009 | Sanyo VM-D6 Camcorder
My sony handycam was stolen how do i play back my 8mm tapes is there an adaptor available?
No adaptor for 8mm tapes. You need to have Sony camcorder or video-8 player for playback these tapes.
Feb 21, 2009 | Sony Handycam CCD-TRV87 Camcorder
8mm Samsung camcorder: choppy playback
This seems like a tape playback problem. Can you look at the output of the tape in the camera directly into a monitor? And checking the tapes on another machine would also be good.
The fast movement breakup can be something in the playback circuitry of the camera. It may not show up in the viewfinder. Also yo umay try repacking the tape. Fast forward it to the end and rewind it all the way.
Oct 03, 2008 | Video Cameras
8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Jun 10, 2008 | Video Cameras
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
Mar 25, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Can an adaptor be used to play my 8mm tape in my VHS VCR?
With the Sharp Viewcam ®, there's no need to use an adaptor to play 8 mm tape. Simply connect the Viewcam ® to the TV or VCR for playback. You can even use your VCR to make a copy onto VHS tape.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Samsung VP-W90U Camcorder Logo
21 people viewed this question
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
