Question about TruTech PLV16190 Television
When i plug a dvdplayer or another device i have to put the volume level high cause this doesnt hear
    Scholar:
  • 65 Answers
What is this that doesnt hear it makes no since the question you asked but if your saying you have to raise the volume all the way up to hear what your watchin then the cables your using may be bad if not the cables then it is the tv input sound board for that input if its not that take the tv back and wip the sales person who let you buy the tv because you got a defective tv
Posted on Aug 28, 2009
When I plug my headphones in why doesnt the sound come out of the headphones?
Where do you plug in the phones? if it is an iPhone. the music playing will be stopped, just to precent your ears to be damaged. When plugging in headphones, while the volume is high, the sound level can be so high, you can damage your ears. Yes damage that will last the set of your life, because loss of hearing, can't regenerate. For that reason some MP3 played, cill stop music playing, as soon as a headphone is plugged in.
Just start the music that was playing when you did lower he output volume if the music stops.
Jun 29, 2014 | Computers & Internet
Aux wont work
check the devices volume level. I had the same problem with my phone. Every time i plugged it in the phone volume level would go down to about half way. hope this helps
Apr 20, 2014 | Alpine CDA-9833 CD Player
Low output with high volume
sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Dec 23, 2013 | Pioneer Avic-940bt Car Navigation Cd/dvd...
When volume goes high, the system goes in protection and relay's clik is heared
This is not the fault with remote control. Check the load connected to the device. If overload occurs, the device will itself go to protect mode. Disconnect speakers one by one and check which speaker box causes the system to go to protect mode, when volume is incresed. Check that speaker for short.
Apr 02, 2012 | Televison & Video
I stopped having sound coming from the speakers. I checked and we are not on mute, and the volume is turned up high.
Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Mar 19, 2010 | Proview Computers & Internet
I have a compaq presario v3700 with windows xp.It has conexant high definition as audio. I plug in my headset. It works in terms of audio hearing on headset but u can also hear it on computer. Then my...
Don't think its the drivers, because you can hear audio.
Do you have your mic with your headset or separatedly? If with headset, maybe your headset has a physical switch where you can enable/disable mic (seen this feature on some Locitech headsets).
You can also check whether you have Mic muted in your audio control panel. Go to Control Panel, open Sounds and Devices and File - Properties if I remember correctly (sorry, I have Vista now) and put a check before Mic property to bring out the Mic volume level bar to see whether it's muted or not.
Hope this helps,
Tom
Nov 17, 2009 | HP Pavilion dv9000z Notebook
PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Cant hear songs
It sounds like your headphone/hold cable is faulty. Try plugging it into a sound device with a docking bay. If no sound comes out of there either then it's a faulty logic board.
Nov 19, 2008 | Apple iPod MA446LL/A MP3 Player
Problems
Is your call volume turned up? Use the side volume buttons to make sure the speaker volume is up high.
If the volume is high and you still can't hear anything, turn on speakerphone mode. Can you hear anything then?
Can you hear the dings and boops that the treo normally makes while navigating through the menus?
Jan 11, 2008 | Palm Treo 600 Handheld
TruTech PLV16190 Television Logo
44 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
