Question about Dell Latitude C400 Notebook
At first we thought that could be the charger, because we had to twist the cable, but now I bought a new charger and it is dead, doesn't work at all... what it could be????
    Scholar:
  • 57 Answers
Hi,the problem is not the charger,now it is proved. there are only two things which can have problem, first the pin(connector) in which u insert the charger and second problem can be of the battery terminal,which takes the charging. first of all check the pin,and if it is ok then remove the battery and check the termials(they are usually of yellowish color metal) is any of them is broken or has some carbon deposited on them.
there is one more probability tht is of the fuse of the laptop .
there is nothing else other than these three problems.
just check them one by once and you will get the solution.
cheers
Posted on Jul 18, 2009
Will not charge when plugged in
have you tried an external battery charger and a different battery?..... maybe its the camera not sending power to the battery..... or the battery is good and the camera is dead, the external charger will help you decide where the fault is.
Mar 09, 2014 | Nikon COOLPIX Cameras
It keep giving me a message to plug in my charger because my battery is going dead so i bought a new dell charger the original one that goes with the netbook, and it worked for awhile, but now its telling...
it might be the battery, i had the same problem with my netbook the charger is ok but the battery died i can use it if it is plugged even if the battery is dead.you can tried taking the battery off the netbook if it turns on the charger is ok.
Sep 13, 2013 | Dell Inspiron Computers & Internet
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
Issues with it not starting, only with a jump start. The problem is very inconsistant...car might start for a week with no problems?
a common problem is loose battery cables, they are side post and sometimes there are two positive cables on the positive post, if so just grab the cables and see if you can get them to move where the bolt goes through the center of the cable to the battery, if it twists the cables are not tight. Other information needed is when the car doesn't start, can you turn your headlights on or is the battery dead? If the lights light up, then turn the key to the crank position, do the lights dim, if so, you probably have a bad starter. if the battery is dead, you could have something draining the battery.
Dec 18, 2011 | 1998 Oldsmobile Intrigue
My NV5378u stopped charging, thought it was the charger wasn't,bought new battery, again does not charge, why
1)How to disassemble a Gateway NV52, NV53
http://youtu.be/ab0tt7LflHw
2)Gateway NV Laptop Repair Fix Disassembly Tutorial
http://youtu.be/f65ohS_EfdI
Dec 09, 2011 | Gateway NV5378u Notebook
Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
Jan 27, 2007 | Insignia I-PD720 Portable DVD Player
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
Dell Latitude C400 Notebook Logo
56 people viewed this question
Alun Cox
