Question about Canon PowerShot A95 Digital Camera
E18 error w/sound effects!
When I turn on my PowerShot A95, the lens glides out, then glides back in. Then the camera makes a staccato grinding noise, once, twice, three times. Then I get the E18 message. I've tried taking out the batteries and putting them back. I've tried holding down the power button for 15 seconds.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Jul 30, 2009
When Canon Powershot A95 turned on, lens opens, CHEEPS, then closes, followed by 6 sequences of 'clicking chatter' and further CHEEPS. Message 'E18' appears in lower left of CCD.
It is Fixable around $100 - $150.
http://www.e18error.com/
On the above link, you would see a Lawsuit against Canon for the same.
This Error usually Requires a Replacement of Lens which is not cost effective relative to the cost of the Camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 23, 2010 | Canon PowerShot A95 Digital Camera
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
When I turn the camera on, it flashes E18 on the screen, makes a grinding noise and the the lens retracts
Has the camera been dropped or bumped hard?
The lens sounds like it has been knocked out of line. Had a old Kodak with the same problem. Might want to start looking for a new camera. Cheaper than repair probably.
Dec 07, 2009 | Canon PowerShot A95 Digital Camera
After turning on, the lens opens and extends, then it makes a noise like thereis something mechanically sticking. After it stops making noise, there is an e18 on the LCD.
The e18 error is a lens error and it comes out if the lens is stuck. It happens for several reason, but it all boils down on how you store your camera. Sometimes, you might have sand in the lens.
I had the same problem before but it was because of the trapped moisture in the lens. If you constantly go out in the sun, it is best to have put your camera inside a bag. Also, dont sun bathe and go inside an airconditioned room too fast.
If you wish to know more about me, you can contat me on my professional writing services site or through my brighthub profile at http://www.brighthub.com/members/writersnetworkonline.aspx
Aug 06, 2009 | Canon PowerShot A95 Digital Camera
Canon A95 Cannot be switched off
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 05, 2009 | Canon PowerShot A95 Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
E18 on Canon Powershot A95
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
A95 Trouble
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Dec 08, 2007 | Canon PowerShot A95 Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot A95 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
