Question about Dell Inspiron 6400 Notebook
I have the same problem error code 0146
Msg 2000-0146
and its to chose one between start windows normally or lunch back up recovery then doesnt work
  • 4 Answers
I had the same problem and came across the following solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Posted on Aug 21, 2009
    Novelist:
  • 117 Answers
You have a failed hard drive. if you need to save data, pick up a usb to sata on ebay for about 10 bucks and you hook it up to another computer with your dell hard drive and you can save files. from there you can try to reload the machine with the backup disks but i recommend replacing the hard drive and starting from scratch to avoid future issues
good luck!
Ruben
Posted on Jul 19, 2009
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Error Code: 0146 Msg: Error code 2000-0146 Msg : Unit 1:DST log contains previous error (s) please help me, how i can solve this problem
I am assuming that this is a problem on a dell computer? If so that error message is an indicator that your hard drive is probably going bad and you need to back up you data and get a new one ASAP. I believe that laptop takes 2.5" 9.5 mm sata laptop drives
May 17, 2011 | Computers & Internet
I had Dell Windows XP along time ago. I now have Windows Vista Business and I think it is Service pack 1. I pressed F12 and did diagnosis then it scanned right off the bat it says... "Error Code...
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
DELL portable XPS M1530 Error Code 0146 Msg = Error Code 2000-0146
you have a missing start up driver try to trouble shoot run windows on f12 promp f2 then asked to run windows run windows.
Feb 04, 2011 | Dell XPS M1530 Notebook
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Aug 03, 2009 | Dell XPS M1530 Laptop
2000-0146 is indicating a hard drive failure which is why it won't boot.
Jun 20, 2009 | Dell Inspiron 1501 Notebook
Code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 6400 Notebook Logo
1,129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
