Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
My cleaner will not **** up the water, it is only a few months old
  • 97 Answers
The recovery lid is not on correctly
Posted on Jul 19, 2009
My Dyson v6 is just a few months old, has started "pulsing" even though fully charged.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 02, 2017 | Dyson Vacuums
Tip
Shark Steam Pocket Mop Cleaning Problems
After watching Shark Steam Pocket Mop from the vantage point of Fixya.com for a few months and seeing the many problems that people were having with the Shark Steam Mop streaking their floors and especially hardwood or laminate flooring I decided to do some research and reading about this problem.
What I found was very interesting.
Many people are blaming the steam mop for their problems, when in fact the problem is just coming to light because of the use of the steam mop. It seems that if other cleaners have been used on the floors they leave behind a residue. Then you come along with this mop that produces a heated steam type cleaning and you start to take this residue off of the floors. This then leaves the flooring blotchy or streaking.
So now what do you do with you floors when you get this mop and what will cure your streaking, blotchy floors? There are a couple of ways....
First way is to just keep on using the mop. Many people report that their persistence has paid off and that after a few uses the shine comes back to their floor as the old scum and residue is more completely removed.
The second way is to use a vinegar and water solution to manually clean the flooring before using the mop. This takes a bit more elbow grease, but will get the floor looking really sharp much quicker. Here is a site that tells about that.
So if you are having a heart attack because your mop seems to be making things worse instead of better then don't give up too quickly!! Use it a few times first... it has a 1 year warranty. Or get on your knees with that pail of vinegar water and get the old gunk from all those other cleaners off of your floor first.
heatman101
Here are some other related tips to check out....
http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
http://www.fixya.com/support/r6896271-find_shark_parts_accessories
on Nov 07, 2010 | Vacuums
I have lost suction on my dirt devil vacuum cleaner, I have looked in the obvious places but can't find a problem. It is only a few months old. Thank you
The loss of suction can be on the output side of the impeller also. Make sure that any filters there are clean especially if it is HEPA
Jan 14, 2016 | Dirt Devil Vacuums
I have a powersteamer and it does not spray water when I squeeze the trigger. The clean water tank is full, the cleaning solution is full and this is the same problem I had with my last Bissell steam...
Every line has an O Ring at each end. inspect each one by removing the O Ring for nicks and cracks. Lubricate the with Vaseline and reinstall if ok so they will hold the prime to pump and vacuum up Your leaking O rings will draw air causing your problem and did so on your last one most likely
Aug 07, 2011 | Bissell Vacuums
The spinning brush just stopped spinning. This vacuum is only a few months old. Please help!!!
Hello. The very common reason this happens is that the belt that drives the brush breaks. The fix is to get a new belt and install it. Do not get a generic belt, get an original equipment belt from a vacuum cleaner store.
Jun 20, 2009 | Vacuums
My Bissell shampoo machine will not spray either water or soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
65 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
