Question about Garden
I have a titan-pro 3600psi and i need a unloader vavle cap and a 15metre hose where would i buy them from.
  • lozalawrence Jul 18, 2009
    ive bin asking that site for the last month they ve only got power washers.they are advertising a 15metre pressure hose but have nt had it in stock for the last month,thanks for replying.
  • 10,515 Answers
Check the below mentioned link :-
http://cgi.ebay.co.uk/Pressure-Washer-Karcher-Drain-Cleaning-Hose-15-mts-NEW_W0QQitemZ140334113943QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?hash=item20ac90a497&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1688|293%3A1|294%3A50
They have got 15 m Hose as well.
Let me know, if that would not solve the issue. Check if the Hose would fit in your model as well.
Thanks for using ' Fixya '.
Do rate the solution if 100% satisfied.
Posted on Jul 19, 2009
  • 19,396 Answers
Hi there, as I told you you need to contact the manufacturer at (+44) 0845 6800 962 or email to customerservices@titan-pro.co.uk
To order the parts you may be asked to register into the website.
Regards.
Posted on Jul 18, 2009
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Need part for a Titan 40 saw (gas cap)
ebay... buy a new saw for parts
Oct 19, 2010 | McCulloch Garden
Coleman model APW-120 May have frozen while stored over winter the unit is new but water was not completly removed before storage. Problem motor runs continuosly but there is no water pressure I have...
Whar has happened is that your unloader / bypass valve is sticking. This is due to minor corrosion and having water in the unit over the winter. Most of the time they will sanp out it if you do the following:
Add 3 - 4 oz of oil into the water supply connection and briefly and I mean very briefly switch on the unit then right back off. Add more oil to the water supply connection and then let it sit overnight.
Then next day turn the unit on briefly and let it sit another 30 minutes. After this you connect all hoses making sure to purge the air our of the supply hose BEFORE you connect the to the unit. Then once you turn the unit on rapidly trim cycle the wand trigger. Your goal here is to cause a water hammer of the unloader / bypass valve to get the spring and cupped seal to move in the housing. Pause briefly and see if pressure builds then fan the wand trigger again. This can take a few minutes to get it to work but the routine of pausing waiting momentarily and rapidly tripping the wand trigger is what should get the unit going again.
If this does not work you will have to take the unit apart dis-assemble the unloader / bypass vavle on the output side of the pump and remove the corrosion on the spring and the housing.
Once your done cleaning up the bypass unloader valve before you put it back in the housing place a liberal amount of Lubriplate #105 White Grease on the spring and inside the housing on the mating surfaces. (#105 white grease is available at any Auto Parts store. It is in a 3 - 5 oz plastic tube)
Re-assemble the unloader / bypass valve an it should work like a champ.
Thanks for choosing FixYa.
Kelly
Sep 16, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
2002 Volvo S60 with Engine fault codes
THE 445 IS THE EVAP PURGE VALVE IT MAY BE BAD BOTH 446 IS SAME VAVLE YOU NEED TO SEE IF THE HOSE ARE GOOD ON THIS VAVLE MAKE SHERE NO CRACKS IF NOT PULL HOSES AND SEE IF SOMTHING IN VAVLE ITS NEAR THE CANSTER AND THAT IS NEAR THE GAS TANK UNDER CAR PUT CHECK GAS CAP MAKE SHERE ITS TIGHT HOPE THIS HELPS
Sep 15, 2009 | 2002 Volvo S60
The unloader valve seems to be hanging up!
The o-rings on the unloader may be worn out. Also you have to lube it with extremely good waterproof grease
Sep 06, 2009 | Karcher G3025OH Pressure Washer
Where is the unloader valve on my pressure washer
is not necessarily a cap, but could be a screw in plug, that should be close to the hose hook-up on the pump Inside there there should be a round ball and a spring that you can tighten or loosen to adjust the unloader and if it has been used ALOT, where the ball seats there could be grooves cut in there and you might need to get a valve kit to fix it
Sep 05, 2009 | Karcher 2500 PSI Pressure Washer
Pumps to 20 psi only and keeps running
First clean the unloader valve, then see if it will raise pressure, is the pressure control knob woking ok? let me know also check tank condesation vavle. Let me know if this helps or if you need more information. Thanks for useing fix-ya.Avid101
Aug 20, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a titan pro power waser the 7hp version diesel motor.I cant get it to take a feed from the detergent i want to use! any ideas??
I have the exact same machine and had the same problem. If you've tried running the washer with a water tank as the source, you will know that it needs at least some level of pressure - i.e. the water tank needs to be higher than the washer. The detergent input supposedly work by dropping the little feed hose in detergent.... it doesn't. This needs rigging up with a fixed hose from a container higher up than the washer to create some pressure. Don't forget to put an air escape hole in the top of the container or the liquid won't drop.
I also found the battery on this model needs recharging frequently, at least once a month if used daily. Keep a check on the oil cos when the engine oil gets too low the electric starter won't start it - it acts as though the starter motor is dead, just top up the oil. Always disconnect the hoses and drain them and the machine to increase lifespan. The hoses are only hydraulic hoses meant for hydraulic fluid i.e. oil, so water degrades them over time. Errr... keep the quick release fittings lubricated or they seize up. Can't think of much else.... they work rather well for the money but could do with a properly written English manual rather than a Chinese translation with information all over the place, and none of the above mentioned.
May 09, 2009 | Garden
Bissel proheat cleaning solution dumping out
Replace the soap dispenser, the new one will come with a new vavle. Part # 2101785, or just the cap and valve #2101795.
Aug 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
