Both ovens on my Dynasty 48" range stopped working on the same day.
I replaced both igniters and a gas coil.
Still wouldn't work. The technician I called was pretty helpless. It might be this, it might be that...
Anyone knows what should be the next step if the igniters are replaced and the ovens still would not work?
Replace the gas valve, this is always the most common problem.
The flame sensor has to sense the flame or it won't light The
pilot flame should heat the tip of the flame switch's sensor bulb to a
red colour. If the flame switch detects sufficient heat on its sensor
bulb at the pilot, it will close an electrical contact in its base.
Once the thermostat is turned on, current will be allowed to flow
through the flame switch to the oven valve to allow it to open. If the
flame switch's sensor is not heated sufficiently, the electrical
contacts of the flame switch would remain open preventing any power
from reaching the oven valve which in turn would prevent gas from
flowing to the oven burner.
In a properly
operating system it should usually only take in the area of 30-45
seconds for the oven burner to receive gas and to light.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Problem seems in the display control, check that first....
Post further comments for more information...
Good Luck!!
thanks
There is no display control I am aware of. It rather looks like the gas is not released by the valve.
i spoke to the company and they insured me that these ranges are usually prety simple and rather mechanical.
Both ovens on my Dynasty 48" range stopped working on the same day. I replaced both igniters and a gas coil. Still wouldn't work. What should be the next step if the igniters are replaced and the ovens still would not work? It looks like the valve does not open gas after igniters heat up. it does smell a little bit of gas thou...
Thank you for the scheme.
I do generally understand the principle such ranges are working on. The question really is what to DO next. which part I should be looking for, or could it be the wiring, or is that a gas valve?
I need to know which direction to move to.
Thanks
The problem was much simpler than that.
After changing of both igniters for both ovens and the gas coils the problem could not be complicated.
It was a little gas valve supplying gas to the ovens. It has a manual override which was closed (probably by accident or shut because igniters had to be replaced). it is located on the right site next to the manifold ON the gas line leading to the ovens. The tumbler had to be lifted and it solved the problem.
Simple-stupid, as usual.
Thank you for your help and if anyone else run into such problem in a future, you might have a solution.
