Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
The LCD screen will not come on when I depress the power button. The unit worked fine when I used it several days ago. It has not been dropped or jarred.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
I would take the rangefinder battery and have the voltage checked. If you don't have a meter....radioshack will test it. It should be 3 volts a little more or less(2.9 to 3.2) if its good. Also make sure its in correctly. Positive end goes in the unit first. (flat side of the battery up towards you when you put the battery cap on) Make sure that little spring on the battery cap is there. Sometimes I pull that spring out....just a little to make sure its putting enough pressure to make a good contact. If you purchase a new battery and the rangefinder eats it up in a few days...You have a battery drain problem...This should be covered under warranty.
good luck to you!!
mtg
Posted on Jul 22, 2009
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
I cannot get the LCD view screen to work ?
There should be a menu button on the camera. if there is, go into the settings and turn the LCD Screen back on. (Actually if you press the menu button on the camera, you should see the menu on the LCD screen.) There is an option to turn off the screen to save battery life.
Dec 17, 2008 | Nikon D70s Digital Camera
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Balnk white screeen on my A610 powershot
unfortunately since the problem is on the hardware (lcd screen), there is no way of fixing it except from the people of the service center.
Jan 14, 2008 | Canon PowerShot A530 Digital Camera
No sound from center channel
Try a Master Reset on the unit. All of your settings will have to be re-entered but it may solve your problem.
For a Master Reset: unplug the unit. Depress the SPEAKER A and the SPEAKER B buttons on the front panel at the same time and hold them in. While still depressing those buttons, plug in the unit to the wall outlet THEN release the speaker selector buttons.
Oct 18, 2007 | Denon AVR-2802
Image dissapears but there is sound
My sister owns this unit, and like other users on this post, her screen quit working on her. She brought it over to me to see if I could fix it before she tossed it out. I first hooked the unit up to the TV with supplied A/V cables to see if the unit was outputting video. The unit supplied video to the TV fine, so I figured the problem was with the LCD screen or the connection from the unit to the LCD.
Like another user on this post, I noticed that the video would come on for a second or two when the small depress button was pressed, but then go blank again. (This button is at just below the LCD screen on the base unit – toward the middle of the base unit. You can see there is a small notch on the LCD screen that fits into this depress button when the unit is closed. This allows the unit to know when the LCD screen is closed.)
Here comes the fix that worked for my sister’s unit – I hope it works for yours also. . .
I decided to reset the screen to the factory settings through the setup menu. This is difficult to do when the screen is blank, so I figured I would have to go hook the unit up to the TV again in order to see the setup menu. Well, I had already put the AV cables away, and I felt too lazy to dig them out again. I decided to just navigate the setup menu by pressing the depress button on each menu, which the second or two of video would give me ample time to navigate the menu. Once I was in the first setup screen and depressed the depress button the screen came on like it had been doing when I was trying to view a movie, but low and behold it did not go off like it had been when trying to view video. Since I was in the setup screen I decided to reset the unit to factory default. I then exited the setup and played a movie. The screen did not go off. I have tried to get the screen to go blank again, but it stays on. It sounds like the problem is not with the LCD screen or its connection, but rather with the operating software of the unit. It is a piece of junk, but it is working for now. I hope this helps with your units also.
I also noticed some users posting a problem with an upside down screen. Hold down the mode button and the screen will cycle through different settings … one of which is upside down.
May 02, 2007 | Polaroid PDM-0723 Portable DVD Player
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
562 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
