Question about Bose Wave Radio
I own a bose radio/cd (top load) with pedestal. Last night one lightning strike affected power in my home before I could get things disconnected. Now with everything reconnected, my radio FM and AM is very staticy -- even on close strong stations that my cheaper radios are having no trouble with. Since the power cord is the FM antenna, I have played around with it for best reception, and it still has some noticable static. Before this happened there was no static at all, no matter how the cord was situated. BTW, everything was plugged into a surge protector. What do you think the problem is? How expensive would be the repair? Where is the closest repair place to Derry, NH?
    Top Expert:
  • Bose Master
  • 12,718 Answers
The tuner section may have been toasted by the power surge that affected your home. See if there is another option for an antenna connection and try that. If not, then it does not appear you have much choice.
U might want to contact Bose for an authorized factory repair station in your area.
Posted on Apr 01, 2017
  • 20 Answers
SOURCE: bose wave radio static only
Try replacing the battery (turn it over, have a look on the bottom there will be a door for a battery) and then trying it. Alternatively connect a aerial as it sounds like a reception problem.
Posted on Dec 11, 2008
SOURCE: no fm or am reception on my bose wave alarm clock radio
I had the same problem took off the two screws in the back and one under the cd cover once I took it apart the am rod was loose i put a piece of duct tape to hold it down and it works great, don't drop it anymore
Posted on Mar 25, 2009
  • 74 Answers
SOURCE: i have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Posted on Dec 18, 2009
neutronrace
  • 66 Answers
SOURCE: CD player on Bose radio started making a click sound
did you clean the laser inside? that a thing I would do first
after that mail us again
Posted on Feb 15, 2010
BillB-SA
  • 2761 Answers
SOURCE: Following a direct lightning strike to our pole
Bose does not release their schematic diagrams or parts lists, so factory maintenance is about the only way to go. You can start the process by visiting www.Bose.com, but be ready for some sticker shock. Before you do anything though, every Bose has a line fuse inside the case. The location varies by model and date of manufacture, but if you open the case it will be simple to locate. Check it, and replace it if necessary. The fuse is there to safeguard electronics against power surges, so it is your likely culprit.
Bill B
Posted on Aug 01, 2010
Which circuit board on my Smart TV might be broken after a possible lightning strike. There are two main ones. The power is getting to the unit, but I can't get the menus, connections etc to work.
Nobody can predict, what might have been happened to your TV after a lightning strike. Do you thing anybody can? Is any technician have a super-natural power to predict the faults that might have been happened due to lightning (More than 10 Million volts to start on stroke) ? Can you?
Sorry.
Contact the authorized service center. OK?
Jul 29, 2015 | Toshiba Cinema 47L7200U 47" 3D 1080p...
Bose 321 will not power up after power surge or possible lighting strike on our boat , tried 60 second reset
Do you have power to it or are you just doing the reset procedure with it dead? If you had a lightning strike then you need to check everything starting with the fuses wiring and if it applies the inverter. No brainer check is the battery itself.
Nov 12, 2012 | Bose (321GS) System
We had a tree struck by lightning last night. Now, our truck and sports car, parked 10 feet away, are both showing problems with charging system, (truck) and ABS, tracking system, and active handling...
Yes. Although the tires are suppose to insulate, there is enough humidity to allow the air to carry a charge. The ECM for example, can be interfered with by Radio frequencies. A lightning strike produces all kinds of freqencies beyond visible light.
You should document the tree strike and park your vehicles back into their spots if you do not already have photos of the tree damage showing the vehicles in the foreground or background.
This is comprehensive coverage with hidden damage discovered within a recent timeframe of the original event.
Aug 03, 2011 | Ford F-150 Cars & Trucks
I have one of the old top-loading wave cd/radios. Last night there was a crackling sound inside and then there was a bang internally and a very small amount of smoke and power failed and it went off. There...
Bose will replace this older top-loading CD WAVE model with a newer one for $200 plus $10 shipping. It's a fairly decent deal, considering a new system is $500. Call Bose Service at 800-637-8781
Oct 13, 2010 | Bose Wave Music System CD Shelf System
Following a direct lightning strike to our pole transformer, transformer blown ,, replaced ,, several electronics not working including our Bose Wave Radio (no CD) ... Where can we find repair and how much...
Bill B
Aug 01, 2010 | Bose Wave Radio
Lightning Strike
The audio amplifier IC damaged need to be replaced
Jul 07, 2010 | Bose Lifestyle 12 System
Bose Wave Radio
Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Jul 09, 2009 | Bose Wave Radio II
Display stays in dim mode AWR1-1W (later version) brief power outage
Yes I think you're right.
You are lucky this is all it is.
Bose do not seem to supply spare parts direct to the consumer, and I'm afraid lightening isn't covered in their warranty. If you want to return the unit to Bose, first you need to call them to obtain a Return Material Authorization (RMA) number. This number helps them track the status of your product. In the United States, call 1-800-367-4008. Monday through Friday, 8:30 AM to 7:00 PM ET and Saturdays from 9:00 AM to 3:00 PM ET. International customers, click here to find the facility closest to you.
Have the following information available when you call:
  • Product model and series number, if applicable
  • Serial number(s): Please note that Lifestyle® systems have separate serial numbers for the music center and Acoustimass® module
  • Date of purchase
  • Details of the problem you are experiencing
  • If your product is no longer covered under warranty and you plan to send it to Bose Corporation for repair, please have your credit card number available.
Alternatively - find another damaged system with a different fault, and swap assemblies.
Hope this helps.
Jun 09, 2008 | Bose Wave Radio
Bose Wave Radio Logo
172 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
