Question about HP Office Equipment & Supplies
Opening an older HP Scanjet 3300C case ??
With an older (HP Scanjet 3300C), I have nothing to lose by ''learning'' to open the case myself in order to clean the ''fog'' off the bottom side of the scan-plate-glass....if i break something... fine.. goes in the trash....... but i would hope someone out here knows the secret to opening the case without causing irrepairable damage... I have already discovered the several ''TABS'' along 3-sides of the printer that i can deflect with a ''slotted'' screwdriver to separate the case.... BUT.... then my access is Thwarted by unknown physical ''locking mechanisms'' preventing full separation of the upper / lower halves of the unit.... does anyone out here know what is preventing me from opening the top? part of the case (nearest the hinges)????????????????
I recently picked up a SJ 3300Cse and have the same issue.
On mine, on the top of the scanner near the hinges there are two small white rubber peices that are very well camoflaged. If you remove them you'll see the two screws to open the hinge side of the case.
Good Luck.
Posted on Aug 01, 2009
  • toonaimiak Jul 29, 2011
    I had this same problem. Want to turn it into a light box.
    After searching the net, with no luck, and almost snaping the whole plastic case in half... I found the damn screws!
    There are two little white rubber things, one on each side of the holes where the lid cover thing goes.
    It's hard to explain but there are only two of these on the side with the glass, so.. Good luck, I guess.
    You pull those rubber things off and the screws are under them... Forgot to add that.
I need to have my HP 3300c scanjet scanner work on vista. Any solutions?
call the hp toll free hotline, they can further assist you there
Feb 15, 2010 | HP Scanjet 3300c Flatbed Scanner
HP ScanJet 3300C Drivers for Mac
My 3300C is back from dead. It's ALIVE!!!! I am not a geek - just a stupid gene cloner/researcher/academic faculty/administrator (I have never changed oil in my car). The steps I took are as follows (the order is important): 1) Go to "http://www.ellert.se/twain-sane/" and you will see a scary table. Do not get intimidated. You will only download "packages" under the system your mac is running (check "About This Mac" under apple). Forget the rest. 2) Open "Libsub - binary" and install it. Then open Libsub SDK and install it. 3) Open Sane Backends - and install binary and then SDK. 4) Open Twain-Sane Interface and install it. 5) Open Sane preferences and install. I then restarted my computer (may be not necessary) and opened Photoshop - under File>Import, I had a new option "SANE...". It found the scanner and presented an extremely funky window to adjust coordinates some choices. Don't mess with coordinates, choose "Preview" instead. Give some time for scanner to respond. A few groans later preview is presented next to the funky window - adjust the coordinates and scan :-)
Apr 08, 2009 | HP Scanjet 3300c Flatbed Scanner
Scanjet 3300c does not work in WindowsXP
I had the same problem and was having no luck with suggested solutions from HP. But the following procedure did work for me. It disables WIA, the built in XP scanning software. See http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1280600613997+28353475&threadId=124494
1. Right click My Computer.
2. Click Manage.
3. On the left, click the plus sign on Services and Applications.
4. Double click Services.
5. On the right side, scroll down to Windows Image Acquisition (WIA) and right
click.
6. Click Properties.
7. On the General tab, set Startup Type to Disabled.
8. Click OK.
9. Exit Computer Management.
Mar 19, 2009 | HP Scanjet 3300c Flatbed Scanner
Scanjet 3300c on windows vista
sorry but i need u to read this.
locate ur unit its down page
click here
plz rate this post
Feb 08, 2009 | HP Scanjet 3300c Flatbed Scanner
Scanner doens't work on Vista
Go to the HP website and under the support section see if there is a windows vista driver available for your model #. If there is then download & install. Scanner should then work. Hope this helps & please remember to rate my answer. Thanks.
Jan 08, 2009 | HP Scanjet 3300c Flatbed Scanner
Hp scanjet 3300c will not power up any more .... worked fine the last time used .... is it a matter of replacing a fuse .... can i do it myself?
Of course, check all the power connections and be sure it isnt a bad power adapter, there isnt usually fuses in a printer that can be easily replaced. If its under warranty, use it and get it fixed.
If its just plain unrepairable, just get a new one at walmart or somewhere. I got a new HP all in one that hasnt had any problems since i got it 6 months ago.
Avoid Lexmark or dells printers, They ****
Dec 01, 2008 | HP Computers & Internet
Scanjet 3300c
HP / Microsoft Vista does not support this scanner. Here is a list for reference....
HP Scanner List
Aug 15, 2008 | HP Scanjet 3300c Flatbed Scanner
HP Scanjet 3300c Flatbed - Vista Driver
Downgrade back to XP. That's what a lot of people are doing.
Dec 30, 2007 | HP Scanjet 3300c Flatbed Scanner
Hp.scanjet
http://www.softwarepatch.com/utilities/hp-3300c.html
Dec 02, 2007 | HP Scanjet 3300c Flatbed Scanner
264 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
