Question about Waterway Above Ground Hi Flo Pump
My pump is humming but not pulling in water - Waterway Above Ground Hi Flo Pump
  • 32 Answers
Is motor turning?
Posted on Jul 20, 2009
NEFF dishwasher s9vtif bottom of the machine is full of water after finishing the wash
Hello. You might have several issues at work here. The drain hose might have a clog in it, the drain pump could be jammed or defective, or the main board could be bad. Use a wet-dry vac to pull water out of the unit through the drain hose(you'll have to disconnect it from under the sink) Be prepared, it might be really nasty inside with rancid water/food. Sometimes, you can get a clog to clear by doing this. Next, you'll have to have access to underneath the unit. Listen for the sounds of the drain pump working--it should be humming, trying to pump water out. If it's humming but not pumping out the water, chances are good that there is a clog or the motor is jammed by debris or food. There should be 120 volts at the motor when it's running. If you have the voltage but no humming, good possibility the motor has an open winding and needs to be replaced. If there is *no* voltage when the pump should be running, then the problem very well could be a defective main control board. I hope this helps you!
Dec 18, 2015 | Neff Dishwashers
Lg wm2277 does not drain or spin
if it does not drain it will not spin humming noise is probably something jammed in the drain pump if youre machine has a clean out you can access the inlet to the pump and clean out the debris from there if not you will have to pull the hose off . if you bail as much water as you can from the tub and tilt the machine back at a good angle it will be possible to get to the pump without having to get a shop vac to clean up the water after words.
Apr 07, 2014 | LG WM Washing Machines
Pentair challenger hums but does not spin
check wiring see side of motor 120 volt vs 240 volt if 120 volt have to move some wires
Oct 02, 2012 | Pentair 2 hp Challenger Pump
1.5 HP PUMP JUST HUMS?
If its the "hum" that bothers you there can be debris in the impeller, take out the pump basket, reach down and feel the plastic blades beyond the hole at the bottom of the pump, should be smooth and clean. Hair often builds up at this point and causes noise. If this is a water flow problem I'm assuming its an in-ground pool. When you "prime" the pump make sure you are pulling off only the main drain.
Nov 25, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Loud hum and water still in the machine
sounds like pump is not working. pull 3 screws out of bottom front panel. that gives you access to pump motor. pull rubber boot off pump and check for stuff, if that doesnt work replace pump
Oct 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity washer: Straining water pump? Humming.
more than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
Apr 03, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer won't drain or spin. When it gets to the spin cycle it just sits and makes a humming noise. It's full of water and I need help! What in the world could it be?
kinked hose or blockage in the water pump you defininatley have material in the water pump
disconnect washer all together pull out after you drain the water by hand as far as can go use a dolly take out side drain the rest by tipping on side you might need 2 or 3 people to get the washer out with little water left when on side pull the water pump off look inside and pull material out with a pair of needle nose pliars that clamp you will need 2 people to pull out material one to hold the pump and one to pull material out with pliars
once done before you put back together do a lube on your washer with appliance oil this will insure good maintenance
what i decribed at top is the non costly way to fix your own washer if there is material stuck in water pump
Jun 13, 2008 | GE WBB4500EWW Top Load Washer
Model#WWX645RBS0 Washer stoped in middel of cycle and now it only hums when I try to run it could it be the timer or ? thank you Ken
if its the timer timer will not move past mark for a length of time reset timer and run threw cycle
if humming the motor has gotten seized up for some reason usually its the coupling that they put between motor and shaft it would look like this
these tend to break these are only 3 dollar parts causeing the hum in the washer
this is a water pump sometimes old socks and or clothing or material get stuck in this pump take apart look in side to see if clogged
if clogged with material get a long needle nose pliars and i mean long and pull materual out it will be tough 2 people one holding one pulling the material pull it threw the inlet direct back out the way it went in it wont come out the other outlet and remember theres always replacement pumps if theres something stuck inside there at good prices
what you described at the top had happened to me and i had to pull the pump found out one of my kids socks was in there i pulled it out with needle nose pliars put back together and washer worked since then
May 29, 2008 | Westinghouse Washing Machines
Washer ax6245wv0 roper washer
  Sounds like something in pump.  This is causing motor to hum and not turn.  Motor is going off on thermal overload.  This is why the humming stops.  It may be possible for you to tilt washer back and access pump.  Remove clip on bottom and top and pull pump off motor.  Try and turn pump.  Remove hoses and see if you can see obstruction.
Oct 14, 2007 | Roper RAS8445KQ Top Load Washer
Waterway Above Ground Hi Flo Pump Logo
382 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
