I am unable to find the window that gives me the amount of color I have left in the cartridges and which one needs replacement.
  • 1,511 Answers
You need to install the Printer Utility which will be given to you by your Vendor in a form of Installation CD.
This installs drivers as well as that utility.
Like for Me it is;
HP Solution Center and
HP Deskjet Printer Software.
Go to the homepage of your vendor, select your product and download the utility software, that will tell you what you need.
And Note that the low ink warning and stuff like that is based on the papers you have printed and the cartridge size (So its not up to the mark)
If i was helpful ,kindly do Rate!
Posted on Jul 18, 2009
I have a 3800dtn. Replaced the blue cartridge and now I get error 54.17 and message says turn power off and back on. I did and I still get the error.
You need to clean any accumulated toner out of the area near the top of the cartridge cavity. This error indicates that the printer was unable to perform a color plane registration on the cyan cartridge. Any chance you left the pull tap in the cartridge?
Sep 22, 2014 | HP LaserJet 3800dtn Printer
Clogged ink jet printer
replace cartridges or wipe them with cotton balls soaked in alcohol.
Mar 18, 2013 | Epson Stylus Office Equipment & Supplies
I accidentally filled a 121 black cartridge with blue color yesterday. I have tried to remove the blue color so that to fill a black one but it has failed and when I print, it only print the blue color.I...
Did you remove all the blue ink from the cartridge? It is possible that there is still a small amount left. Just keep on printing until the blue ink runs out and the black ink will replace it.
Oct 27, 2011 | Office Equipment & Supplies
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Color ink cartridge
Well due to some problem in cartridge you would be facing this problem.however you can do try this.
Please clean your cartridge once again with some spirit.
Fix it well in the printer afterward.
Than use normal paper and print in color.
If than also it does not work that means the bar-code of the cartridge has problem in it so the printer is unable to read that code, so for that you need to change the whole cartridge.
Or if your printer had valid in warranty period and it still in that period just give it to a service center.
If you still had any confusion regarding the same problem or nay other please do reply.
Naiven.
May 31, 2010 | Lexmark X4270 All-In-One InkJet Printer
HP F4280
Once you open the front panel with the printer on, you should have the ink brought to you. Both should all come to the front from the side of the printer so you can replace it.
Aug 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
Cannot tell which inkjet color cartridge needs changing
Disregard the monitor information and rely on the printer.
On the left panel of the printer are your indicator lights and buttons. Push the button immediately to the left of the 'ink drop' light [looks like a little tear drop]. Open the cover and the printhead assembly will move to the left and stop. Look very closely and find that little 'ink drop' imprinted into the plastic in the very middle of the printer where the printhead assembly stopped. That 'ink drop' will line up wih the ink cartridge that needs replacing. Push that button on the left again and the printhead assembly will either return to the 'replace' position, or move to the next ink cartridge that needs replacing. Keep pushing that button just once at a time until the printhead assembly identifies all cartridges that need replacing and moves into the 'replace' position. This 'replace' position will be on the right side of the printer where the opening occurs that allows the top cover of the printhead assembly to open.
Change the appropriate cartridges and you should be good to go.
Mar 18, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
KONICA MINOLTA 2430DL
do trust the computer replace the each unit and use only Konica Minolta units third party can give bad problems
Apr 15, 2017 | Konica Minolta Office Equipment & Supplies
jasbo
jasbo
