Question about Technics RS-TR272 Single Cassette Deck
My record button won't go down. How can I fix it?
    Problem Solver:
  • 18 Answers
This is normal if the cassette tape has a broken tab. Try a different cassette or inspect the cassette to ensure that the write protect tab is not removed. where to look? On the cassette opposite side to where the tape is there are two possible places, each on the side of the cassette case. The broken tab is a feature that prevents accidental recording over an existing program. It also stops the record button from being pushed. The tab is a plastic part that is easy to break with a pen tip.
Posted on Jul 18, 2009
My tape deck record button is stuck and won't go down.
Posted on Dec 06, 2010
Recorder button does not go down. . Is there anyone who knows how to fix this problem
There is an interlock that prevents accidental recording. You may have to press PLAY and RECORD at the same time.
Jan 01, 2015 | Sony Tcm939 Table-top Tape Cassette...
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Swan dvr wont record
It sounds like a problem that might be an easy fix. Since the system CCA board doesn't see the HDD. Can you view any previously recorded images? How are the connections to the drive? Bad IDE ribbon cable (yes do do fault), power to the HDD and how about the drive? Some of my DVRs require the manufacturer drive, not a simple off the shelf (i.e. Lanex or Verint).
Try that and reply back. :)
May 22, 2013 | Home Security
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
My i pod touch is blank, i've followed the relevant stepr to restore it. after which an error code was given on i-tunes, i followed the steps given for the error but my i pod is still doing...
Try this:
Hold down the middle button (home button), the power button, and the volume DOWN button (make SURE that it's not the up one. It won't do anything, but it won't fix your iPod. Only the Down button will.).
Hold all of these down until the Apple sign shows up. Once the Apple sign shows up, it SHOULD work.
I hope this helps!
Jun 15, 2011 | Apple iPod touch
My rr dr 60 will not recoerd it says on the screen full ,but all the memos have been deleted
The way to fix this problem is to take out one battery, then HOLD down MENU button and PUSH wheel IN....then reinstall battery as you hold down those two buttons. This WILL fix it. I had same problem before. Is a very common issue with the DR60.
Nov 20, 2009 | Panasonic RR-DR60 Digital Voice Recorder
Sony icd-320 handheld voice record.
The erase button is on the right hand side of the recorder. When you are on the message that you want to delete, then hold the erase button down. The message will start to play and an erase message will flash. Push the erase button down again and it will delete the message. Continue to do this for each message until you have the desireable amount of free space.
Oct 25, 2008 | Sony ICD-P320 Digital Voice Recorder
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Technics RS-TR272 Single Cassette Deck Logo
2,378 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
