Question about Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean? Newslady48@tampabay.rr.com
    Problem Solver:
  • 12 Answers
Usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Posted on Jul 19, 2009
The USB plug has loosened itself inside the hardrive how do I fix it?
Look up Verbatim in the phone book. Find their phone number. Speak to customer service and they will repair/replace your unit free of charge, even if you don't have proof of purchase. I know, I just got my unit back, all fixed!
Mar 23, 2014 | Verbatim 160GB USB FireLite: The "drive...
Why does blue light blink and then desk top no longer reconizes it ?
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Dec 31, 2010 | Verbatim 160GB USB FireLite: The "drive...
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
Hey there not sure if both usbs on this dual cable are to be plugged into my PC. The drive keeps flashing a blue light but my computer is not recognising it.
In most case's only one USB needs to be connected, but you need to load the driver for it from the disks which you would have received for it.
Hope this helps.
Thanks
Jason
Oct 14, 2010 | Verbatim 160GB USB FireLite: The "drive...
I CONNECT EXTERNAL HARD DRIVE TO PC WITH XP AND IT DID NOT RECOGNISE EXT HARD DRIVE HELP PLEASE
dear sir
good day
try to replace the USB cable and test the Hdd on an other computer system to make sure it is function and good luck
Dec 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
I just got a Verbatim 320 GB/Go, USB 2.0. I have a MacBook running OSX (10.4.11). When I plug it in, there's a flashing blue light, no sounds or anything. According to the website, this only happens in...
First let me let out a LMAO to there website. Although the Windows and Mac operating systems are still somewhat different in how they work, the computer you're running OSX on IS a standard "IBM-Clone" or PC and therefore and potential hardware issues are identical regardless of wether it is running Mac or Windows.
The Blue light blinking generally means one of only two things, one the hard drive is active and currently reading or writing files, or two, it has a hardware problem. The fact the light is on usually means you have a good power supply but there are numerous other problems that could cause this.
If you just bought the drive and haven't got any data that is only on this drive, take it back to the store you bought it at and ask to have it replaced as a faulty drive. If you do have any crucial data on the drive already, respond back and I will be happy to offer advice on how to retrieve it.
Chris
Aug 15, 2009 | Verbatim 160GB USB FireLite: The "drive...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
Jun 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive Logo
816 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
