2013 Ford Focus Logo
Marty Holt Posted on Sep 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2013 Ford Focus edge won't pair with my iPhone?
I can't get any Bluetooth connection.
David Hildbold
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Ford Expert 730 Answers
  • Posted on Nov 08, 2016
David Hildbold
Ford Expert
Level 2:
Dedicated:
Answers
730
Questions
0
Helped
74697
Points
962
2 Related Answers
Anonymous
  • 89 Answers
  • Posted on Feb 04, 2011
SOURCE: Bluetooth keeps aking for a pairing code. each 4
Did you try just pressing enter (no code)? If not, try "0000" I found something here: http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Bluetooth%20%26%20Voice%20control/bluetooth%20%26%20voice%20control%20%28cg3504en%29%2001-2006.pdf which indicates "0000" is the code, but enter should do it
Testimonial: "worked with an old module i have, but radio is stuck on mute wid dis one. when i insert my newer module,it dos not pair with the phones but BT show up"
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Jul 09, 2015
SOURCE: What does powertrain malfunction mean in a 2013 ford edge
something happened in the motor compartment that wasnt supposed to
2013 Ford Edge. Location of Block heater cord please?
Not easy to find the first time!
Where is a block heater? - 3.5L
Ford Edge Forum https://www.fordedgeforum.com > ... > 3.5L
Nov 14, 2021 - All Edges are made in Canada, block heaters are never standard on US vehicles, I don't have the 2014 Canada order guide but I do see the 2021 ...
2017 ford edge block heater
Jan 12, 2020
Another Block Heater Question - Ford Edge Forum
Dec 29, 2013
2007 Edge Block Heater cord - - Mods & Tech
Dec 13, 2009
Block Heater - 2008 Edge & MKX
Oct 17, 2012
More results from www.fordedgeforum.com
3answers
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
Whymy 2013 ford focus sometimes won't start i have dash lights and radio ?
Did you take it to the dealer ? Still under warranty .. Do you know the amount of electronics that are incorporated into that vehicle , control modules , C.A.N - controller area network communication's data bus etc.... An you want someone on here tell you the reasons why ! You should read up on it .A lot of testing is the only way to find these type problems . Videos on youtube for basic electrical testing , voltage drop testing etc.... Engine Won Crank or Start
3answers
Please someone help me. I've tried to connect to Bluetooth. I get so far along and then phone Bluetooth doesn't find the cars. Is there a fuse that might if gone? I did not get a manual with my car.
About 4,890,000 results (0.54 seconds) Search Results
    How to Fix Bluetooth Pairing Problems - Techlicious
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
    Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing...-/CP2/
    Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
    Bluetooth FAQ for Windows Phone ' Windows Phone How ...
    www.windowsphone.com/en-us/how-to/.../bluetooth-faq
    Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
    iPhone 6 not connecting to car Bluetooth ' Apple Support Commu
How do i pair my iphone with bluetooth
go to settings >> general >> Bluetooth turn it on and pair with the device
Cx9 bluetooth
Make yours car bluetooth visible when trying to pair with phone
Iphone bluetooth pairing issue
if u pairing with system then reinstall the bluetooth driver and restart the system after restarting again try to pair ur iphone with system .
2helpful
Bluetooth keeps aking for a pairing code. each 4 digit one I tried fails..says:cannot pair with ford audio..using n96 and iphone 4 both fail to pair
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
