Question about Sony Playstation 3 (PS3) Console
My ethernet cable dosent fit. can i use a dsl cabel?
  • 32 Answers
You don't need any cables if you have a wireless router connected to a PC or Laptop in your home, just use that. I do, works perfect and no extra unsightly cables or boxes are needed.
Posted on Jul 19, 2009
    Novelist:
  • 154 Answers
Your best option is to buy a new ethernet cable.
They aren't very expensive and you'll know for sure that you have the correct cable.
Posted on Jul 18, 2009
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I hooked ethernet and dsl phone line to my dell c640 and no internet
    the phone line should be connected to the dsl modem, and from the dsl modem there should be the ethernet cable connected and at the other end of the ethernet cable is the computer.
    Feb 23, 2010 | Dell Latitude C640 Notebook
    No signal to tv
    your av cabeles could be on the wrong setting try to change from hdmi to tv on the end of the av cable that goes into the xbox. if it still dosent work then try to change the imoprt slots or try your cabels on another tv to see if its your cables thats the problem if you get signal on the other tv then its your first tv. but if you dont your av cabels mite be going i sugjest buying a new set if the other options dont work
    Dec 11, 2009 | Microsoft Xbox 360 Console
    I don't know how to connect my router. please help
    If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
    Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
    Vista laptop dosent connect to xbox media exdender/media center
    u either need both need to be hooked up the same way try putting your laptop to connect trough ethernet cabel
    May 21, 2009 | Microsoft Xbox 360 Elite Console
    Connecting dsl modem to dell latitude laptop
    If your DSL modem does not have a phone port or if it has one but it's bigger it's not a phone port, it's called an Ethernet port. Most of the DSL modems/routers they have an Ethernet port. This is how it looks like click here. If this the port that you have on your modem, the cable that is also in the picture is what you should be using to get the laptop connected to the modem. The cable is called an Ethernet cable. And your laptop must also have this ethernet port.
    If you have more question please let me know. Just reply to this post.
    Feb 14, 2009 | Dell (0E828) for Latitude C610 Modem
    Can this be used with a MAC?
    Any router will work, TCP/IP is a network standard, definately double check the cables. Your DSL modem is usually 192.168.254.254. and the router is usually 192.168.1.1. Check your documentation for the default IP. Once you know it type it in to the broswer in your Mac. Before doing so connect with an ethernet cable, purchase a new one if necessary. Connect from the <--> labeled port on the mac, or ethernet port. These wires are not like phone lines, they have 8 wires instead of 4/6. The router usually has ports on the back labeled 1, 2, 3, 4, and WAN. the 1-4 ports are LAN and that is also labeled on there. Plug the mac into port 1 and any other computers in after you get internet. once the physical connection is recognized. Go to your browser in the mac and proceed. if you get a web based router configuration page your router is working, then make the WAN connection to the ethernet port on the back of the dsl mode. Be sure your cables are good. Also go to your control panel and make sure your internet is enabled in your network section.
    Jan 06, 2008 | Siemens SpeedStream 2624 Router...
    How do I connect my cable/DSL line to this device?
    The 3Com® OfficeConnect® Cable/DSL Gateway does not have an internal cable or DSL modem. The gateway router is designed to connect to the Ethernet output from your cable or DSL modem. An Ethernet cable is supplied with the product for this purpose.
    Feb 16, 2006 | 3Com (3CR856-95-UK) Firewall
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
