Power button seems to be broken
The power button has been pushed in, and now won't come out again. Can't turn the machine on, the button is still movable (up and down) but it won't pop out! It's a Zanussi ZJD 12191
    Problem Solver:
  • 9 Answers
The trigger has been damage you have to replace it .if you want i can fix it im a technician
Posted on Jul 19, 2009
  • mitchkyle01_ Jul 19, 2009
    the trigger has been damage you have to replace it .if you want i can fix it im a technician
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Gfdn240gloww power button is pushed in
If it won't pop up, the spring or release may have broken. Full replacement is the only answer if it won't come up.
Jan 18, 2014 | GE GFDN240ELWW Dryer
I ground a coffee cup's worth of beans. And then I changed my mind. So I quickly, pressed the power button and started over. I pressed espresso button and it ground beans again! now it is jammed. Is it...
When you turn it back on you should hear the brew unit go threw the motions. Check to see if the user ground coffee is in the dredge drawer and also see if can remove the brew group
Sep 08, 2013 | Saeco Magic Comfort Plus Espresso Machine
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
I turned on the dryer and it ran for about thirty seconds before it just stopped. I pushed the start button again, but it wouldn't start at all.
Is the motor trying to start? Is there power to its outlet?If it is gas try plugging something else into the outlet to check for power. If it is electric turn the breaker off for ten minutes then turn breaker back on again and try the machine. If you have a volt meter you could check the outlet for power that way. If the motor is running when you push start but the drum isn't turning than you probably have a broken belt. Is the door all the way shut? If so you could have a broken switch at the door. To check the switch would require opening the machine case and using an ohm meter to check the switch. The last thing it might be is the timer. If it is an older (ten or more) unit and it is the timer then it might make more dollars and sense to get a new machine.
Oct 07, 2010 | Roper Dryers
When the push start button is pushed in the dryer starts and every thing is ok until you release the button then all stops. I have replaced the bank of push button and just relaced the timer controls.
Good day,
Seems you've covered the timer and push to start switch.
If so then....
The principle the system runs on is, if the timer is turned on, 2 wires come out of it to run the the motor.
The first goes to the push to start switch and when pressed it sends power directly to the motor.
The second wire goes to the motor, but thru a centrifugal switch that must be up to speed before it sends power to the motor.
That is why it continues to run even when you release the start button.
The centrifugal switch is a part of the motor.
Either the centrifugal switch failed, or the power wire to it is disconnected or broken.
Feb 11, 2010 | Washing Machines
Tv broken?
YOU WILL HAVE TO REPLACE THE POWER SUPPLY IN THE TV
Aug 24, 2009 | Samsung LN-T4671F 46 in. LCD Television
Vienna automatica saeco will not turn on
If you push the power button and the machine will not turn on and it a newer machine there is a reset button on the side of the boiler that needs to be pushed. This will get you [power again. If the machine is older than 3 years you probably need a new board or power filter.
Apr 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
