Question about Dell Computers & Internet
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
  • hansenarch Jul 18, 2009
    Thank you yachtpro, it makes sense.
    The next problem then is that I have not used my HP tower in years, gave my Viewsonic monitor away, and am now trying to re-use it as a temp solution for a friend who has a small Dell monitor. Guess I need to find a 'compatible' monitor first to change the settings.
    This would work, correct?
    Novelist:
  • 109 Answers
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Posted on Jul 18, 2009
  • Art Weber Jul 20, 2009
    If both monitors are CRT type (not LCD) either one should work. Older smaller monitors usually defaulted to 640 x 480 resolution, and as they got larger (17") the resolution bumped up to 800 X 600. As I said, my new flat panel 19" is not a wide screen and runs the 5:4 aspect ratio. Its resolution is 1280 X 1027 which also happens to be the maximum resolution that my on-board graphics card will handle. Try a different monitor. If your HP tower is that old, it may not even handle SVGA graphics,
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
http://www.amazon.com/AmazonBasics-HDMI-Adapter-Cable-Meters/dp/B001TH7T2U
Dec 31, 2013 | HP Pavilion Computers & Internet
How to coonect HDMI CABLE from CPU to Monitor of HP Pavilion
Look for an HDMI port that fits the cable on the back of the computer tower and monitor, also look on the video card outputs on the back of the desktop itself.
Dec 30, 2013 | HP Pavilion Computers & Internet
Mismatched CPU and monitor
According to HP http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07722&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=90841#N1772 and CNet http://reviews.cnet.com/lcd-monitors/gateway-fpd2185w/4507-3174_7-31563945.html?tag=mncolBtm;rnav
These should be able to connect as they have VGA on both machines
Jan 14, 2010 | HP Computers & Internet
I have a HP monitor for 2yrs now. It was working fine until recently I noticed that whenever I boot up the monitor goes into sleep mode and the PC is not coming on. How can I resolve this problem and can...
The problem you are encountering is not your monitor but your computer. There is a problem with your CPU unit. To know this info in true then try this.,remove the connections of the monitor from your own computer then use the monitor to the other computer and see. Hope this could help you determine the real problem.
Oct 26, 2009 | HP Pavilion F1703 17" LCD Monitor
When I hooked up the new Dell monitor my HP computer quit working.
What is the type of connector for the dell monitor? IS IT VGA or DVI. The HP computer is a notebook or desktop. Are you connecting to the onboard video or video card.Check if the monitor is passing self test feature. Then try connecting with HP computer. Good luck
Sep 17, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Screen goes black or sleep mode
try to connect your cpu to other monitor,if its still in a sleep mode,the video card must be the problem,you find this inside the cpu.bring your cpu to the person whos knowlegable in repairing computer.
Jul 13, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Dell computer will not work with an older HP monitor
no dell have set up there computers so you cant use othe appliances that arnt dell. so im sorry for the inconveince.
please rate my help to you.
thank you.
Apr 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I want to know if my monitor is Vista compatable
Yes, the monitor is Vista compatible. A monitor is just a display device, simply showing you what's coming from the computer's video card. That video circuitry is what would need to be compatible with Vista.
If you are upgrading an older computer by installing Vista, you might need to be concerned about video hardware compatibility. If you are upgrading by simply replacing the computer with a new one, it will already be Vista ready. In either case, the monitor will be fine.
Please take a moment to rate this solution if you've found it what you need, and thanks for asking here!
Dec 27, 2008 | HP Pavilion MX70 17" CRT Monitor
M70 crt
just check the power cable from the monitor is connected properly or not try reconnecting it...
may be there is some loose contact in power cable............
check the cable which connects the cpu from the monitor is connected properly check whether is there any loose contact try reconnecting it...........
if problem persists then there is a problem with operating system try reinstalling it....
Feb 10, 2008 | HP Pavilion M70 17" CRT Monitor
Computers & Internet Logo
665 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
