Error code 12 is no problem found. I would make sure I had the right bulb, make sure it is seated properly, and make sure the door to the lamp box is on correctly. If that doesn't work, and you still have the old bulb, put it back in. Even if it doesn't work it will display a bad bulb code and not the current one if your new bulb is incompatible. Sometimes that happens when you get a new bulb with incompatible specs.
Well that doesn't make sense because we had a different code last time and that bulb was sent back to Amazon ...so we had to order this new one and now the code is no errors..but it won't turn on still ya here the noise like it's going to turn on but it doesn't it just goes rite to the blinking red light....I have readjusted the bulb everything is clean so i don't no what else to do .????
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
SOURCE: red lamp light comes on. do i need a tech or can i replace
You will be able to do it your self.. On the back of your tv there will be a door held in place by philips screws. Take the door off and then the lamp is secured by a few more coin screws( a nickle works). Remove them and remove your lamp.. Install your new lamp be very carefull not to touch your bulb. (it causes premature bulb failure..due to the oils on your skin) put all the screws and door back on (will not operate without the door) plug it in wait the 90 seconds for mitsubishi to reset then your done.. here is your lamp part number
915P049010
SOURCE: I replace the bulb and I'm getting a blinking
That code can often be caused by failed capacitors on the power board which will cause the 34 error for lamp abnormality. The V26 Power repair kit at www.tvrepairworld.com may fix that issue. The kit contains the replacement capacitors and has the CD with instructions.
SOURCE: wd-52725 had blue screen no picture or sound
you may be on the incorrect input channel. look for an input or tv video button and choose each input until u get a picture
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
