Question about Whirlpool WFW8300SW
Whirlpool top loading washer will not spin or drain. It does agitate but it will not spin. In trying to look at the lid switch, the striker piece came off. Not sure if that is the original trouble. Can't figure out how to take the top of the washer off to gain access to the lid switch to check it and put the lid strike piece back on. need to see if the switch works. Need to know how to get the top of the washer off or up so I can see the switch & fix it. And if the lid switch is not the problem, and if the drain hose is not clogged or kinked, I need help to diagnose /repair. Original problem is the washer filled & agitates but will nor spin (or drain),
  • Old Dad Jul 18, 2009
    I think it does sound like the lid switch. I am still trying to figure out how to lift the top of the washer up. In the instructions it refers to a consloe and removable end caps. I am not sure what these are referring to. Our washer has a control panel with the knobs and switches. I need to get the lid up to gain access to the switch. How do I do this?
  • 5,911 Answers
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 18, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 18, 2009
    PS With the lid open, you can use a screwdriver to push down on the lid switch contact to see if the washer will start to spin and drain. If the lid strike is broken off, and the lid switch WILL engage with a screwdriver, replace the lid strike. You do not have to disassemble the washer for this.
  • Jeff Rockwell
    Jeff Rockwell Jul 19, 2009
    The operator console I am referring to has knobs and switches and is located on top of the washer. It will either have removable end caps enabling you to access the mounting screws, or you may have a console with release tabs located under each front corner. Sliding a putty knife under the console will release the tabs, allowing the console to lift up. You need to lift the operator console in order to access the brass clips that hold the washer casing in place. Let me know if you still have questions.
My frigidaire top load washer would wash but do not drain or spin.
You will need a lid switch if striker is good. Check your lid switch striker to make sure its not broke( thats the white plastic piece on the lid) good luck thanks for voting......
Mar 20, 2011 | Frigidaire FWS933F Top Load Washer
I have a series 90 Kenmore top loading washer model number 110.26912691. At the end of the wash cyle it began to make a loud buzzing noise. I've tried to reset, the water will fill, but the washer...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026912691/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Initial suggestion is a Lid Switch:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 14, 2010 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore 70 series top loading washer. Model#11020702990. It is a type 111 It will not drain. It fills, agitates, but does not drain.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20702990&pathTaken=partSearch
Older models only used the switch during the drain / spin cycle.
Jun 05, 2010 | Kenmore 24032\24036 Top Load Washer
Machine agitates but wont drain
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
May 30, 2010 | Kenmore 22422 Top Load Washer
Won't agitate
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92596100&pathTaken=partSearch
If it neither agitates,drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 17, 2010 | Kenmore Washing Machines
Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Mar 31, 2010 | Whirlpool LTE5243D Top Load Stacked...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Oct 08, 2009 | Washing Machines
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Whirlpool WFW8300SW Logo
253 people viewed this question
Dan Webster
Dan Webster
Sal De
