Question about LG Washing Machines
WM2487HWMA LG Steam Washer has no power or doesnot start
4 Suggested Answers
SOURCE: LG washer letters smearing!!! WM2487HWMA
is it free
Posted on Jul 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: Front load LG Washer Model WM2487HWMA out of
Maybe one of your damper hinge pins have popped out.
See page 39
Posted on Apr 17, 2010
SOURCE: my wm2487hwma lg washer wont come on, drum light
I have an LG washer slightly different model but had the same problem. It washed the clothes but then the light would stay on but the washer would not turn back on. Remove door switch unplug wire that conects and check the connections. which requiered taking off the top and front of the washer. Mine were corroded after only 2 years. We cleaned the connection and it seems to be working fine again.
Posted on Jan 24, 2011
How to replace a washer pump lg WM2487Hwm just a nose from pump....
pretty straight forward job. but you need to take front off for access. which means top comes off first. so must unstack washer/dryer. check out repairclinic.com or appliancepartspros.com for how to videos.
Oct 22, 2016 | LG WM2487HWMA Front Load Stacked Washer /...
OE CODE ON LG FRONT LOAD WASHER...
Check for blockage,filters hose pump problem?
Jul 30, 2014 | LG WM2487HWMA Front Load Stacked Washer /...
My washer control panel has power to it, but when I attempt to start a load of laundry, it does not start, No error messages, it just sits idle.
Unless it says C.L (Which means Child Lock), it could just be a loose contact point, or even a dirty connection.
Follow these steps:
- Step 1) Cut the power to the machine
- Step 2) Loosen the Facial Panel (Clips on left and Right sides)
- Step 3) Lean open Facial panel, so you can see the PC Board rear
- Step 4) Remove all connections, carefully noting where every connector goes.
- Step 5) Blow away dust, remove fluff or dirt, even check for cockroach eggs. (If need be, use a normal Pencil eraser to clean on the circuit board, this will avoid damaging it)
- Step 6) Reconnect all connection, and re-fit the Facial Panel
- Step 7) Turn power back to machine & Test.
Hope this helped
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
Dryer not starting
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 29, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
My wm2487hwma lg washer wont come on, drum light is on, but everthing else is out , no power. Unplugged washer and reset at fuse box, power came on, but same problem occurred.
Sep 10, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Whats an ie???
IE is water inlet problem...The inlet valves on these machines can be double or even triple valves...Not a big job...Good luck....Nomess
May 20, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Washing Machines Logo
254 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
