Question about JVC Video Cameras
Does the indicator light come on when you plug it in even if the
My camcorder stopped working in the middle of taping. I think it might be the battery. when i plug it in should i beable to turn it on.
  • 81 Answers
I had the same problem last week - turned out to be one of the cells in the standard capacity battery pack had expired. Replace the battery pack (3500mAH BN-VF707U units available from GB£10.25 delivered)
Posted on Jul 19, 2009
VHS TAPE IS VERY SQUEAKY AND TIGHT AND STOPS WHILE PLAYING
I answered this previously, thinking you were referring to the machine, not the tape itself. See if a different tape (perhaps even different brand) works okay. If not, look at the machine. I have seen tapes go bad, but generally it is the machine (or camcorder).
Jan 30, 2014 | JVC DF420 D-VHS Tape
Lights on front of unit stopped working and a little while later the whole unit stopped working while in the middle of vacuuming
Take it to a qualified repair facility. Even as there isnt to much to a vacum let the tech check it out. Could be a faulty switch or controls. I dont think its a serviceable by homeowner problem.
Dec 20, 2013 | Kenmore Vacuums
Charge Indicator light on HV20 never lights
The battery was shipped dead. I charged it over night and the light started working.
Sep 11, 2008 | Canon HV20 HDV Digital Camcorder
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
That is caused by leaking capacitors. Not a lot the layman can do about it except purchase a new camcorder or send it to Panasonic for repair, if not obsolete.
Apr 23, 2017 | Panasonic Palmcorder PV-DV52 Mini DV...
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Power light flashes
It could be the common moisture sensor problem.
Take the base cover off by removing the 4 screws (3 on base - 1 under LCD). There will be two small copper contacts under this cover toward the top/middle. Either just blow on them or if that does not work clean them with alcohol spirit or similar, put the think back together and power up and that should do it - worked for me.
Feb 24, 2008 | Panasonic NV-DS60 Mini DV Digital...
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
E04 Safeguard mode due to Dirt head
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Nov 06, 2007 | JVC 580136 Camcorder
Songy VX2100
I had the same problem when I reused tapes that I had recorded on before, but I don't have this problem when I use brand new tapes. I use Panasonic and Sony tapes and the odd JVC.
Oct 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
Video Cameras Logo
53 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
