Question about LG Shine KE970 Cellular Phone
How do i set my own message tones - LG Shine KE970 Cellular Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
Normally if i get a message on the screen says message received and there was a tone but now, the message symbol is small at the top right hand side and no tone can be heard but i could hear the tone when...
Dear Friend jut check the settings in text message whether the message alert tone is still active or not.
Also chek the profile on which phone is active on,there may be an option in the phone which says the message tone settings.
And also check the tone settings on the mobile
Thank You
Apr 22, 2010 | Nokia N72 Cellular Phone
How can i set message ring tone.
Go to menu>my stuff> tools >utilities. Scroll down > my voice.
Then press record .
To set it as your ringtone:
Go to menu, settings, then profiles. Then it takes you to flight mode, silent, vibrate, ring, and etc. On the side it says options. Select it. Scroll down to customize. Then just change the ringtone or scroll down to message tone.
Jul 25, 2009 | Pantech Matrix Cell Phone
Change message alert tone samsung l700
can i change my message tone to alert tone
Jul 16, 2009 | Samsung SGH-L700 Cell Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
I can not able to set message tone in my samsung l700 set....
There is one solution go to >settings>tones>message tone.
Apr 24, 2009 | Nokia 6500 Slide Cellular Phone
Change the message tone on samsung g600 and u900
PEOPLE WHO WANT A NOTHER TEXT TONE!
You Can Change The Ringtones Of Messages By Going To
Menu> Settings> Phone Settings> Profiles>Normal> Options> Edit> Press Right Button> Down And Change There!!
Hope It Help Youu =]
Nov 27, 2008 | Cell Phones
Message alert tone
hi there ,
             you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps..
Simon
Sep 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Message tones on the samsung u900 soul
go to settings, then choose phone settings. In phone settings go to phone profiles, normal is highlighted click options, then edit, then ok. Click the right arrow then go to message alert tone, click on options then change and ok. Go to use my alert tone choose your tone go to options and click down and select then ok. Then job done.
Jul 13, 2008 | Cell Phones
LG Shine KE970 Cellular Phone Logo
79 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
