Question about HP Office Equipment & Supplies
Hp C5180- magenta and light magenta banning. I tried cleaning several times and changing ink but no change. I also tried wiping the ink cartridge with a qtip. Any suggestions? Thanks
  • 24 Answers
Put the printhead in cleaning windows liquid by a few hours, this will disolve clogged valvles, easy and cheap, it works. Dont sumergeall the acrtridge only a 2 mm.
Posted on Jul 18, 2009
I just changed all of the ink cartriges. Now the magenta and Cyan are not functioning....nothing. Everything is yellow and black, I cleaned the print heads twice, just wasting ink. I tried to align the...
If it worked before changing the ink-cartridges, then it probably is _NOT_ a case of "clogged" ink-jets in the print-head.
Did you remove the plastic "sealing" tape from the new cartridges, before you installed them?
If not, then no ink can leave the cartridge.
Which model of HP printer? Maybe, you got a "dud" of a new ink-cartridge.
Take it out.
Take an old, thick, section of newspaper, and lie it flat on your table.
Dampen a paper-towel, and put it onto the newspaper.
Touch the ink-cartridge to the paper-towel -- it should "bleed" some ink onto the towel.
Not much ink, but the newspaper is there to protect the surface of the table.
If no "bleeding", then the ink-cartridge is the problem.
May 21, 2011 | HP Office Equipment & Supplies
Hp Photosmart C5180 I am unable to get Light magneta and magneta cartridge to work. There is ink in the cartridges. All other work fine. the self test page shows no solid color bars under these two. I have...
Greetings the easy cleaning in the back of the cartridges have a metal connectors should be clean and not be exposed for anything ben ink. Well to solve the problem of the magenta who spends a lot is that you get a new cartridge and inserting it as many times you buy to fill and the ink is so solid that nothing comes out of ink.
Jan 29, 2011 | HP Photosmart C5180 All-In-One InkJet...
I just bought a new yellow ink cartridge, and when I put it in the printer says that the yellow ink is depleted. I changed the ink two times. What should I do?
If you are using off brand cartridges that are remanufactured (refilled), that may be your problem. I have had several HP printers and when I used refilled cartridges, it wouldn't print. I stay with genuine HP ink cartridges. Just my opinion!
Sep 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
"ink system failed"
This could be an issue with the connectors to the chips on the cartridge, make sure the chips on the carteidges are clean then check the ones on the inside of the ink holder, POWER OFF before doing this as you could cause damage to the printer if powered on, lift the lid, wait for the rack to engage the centre then turn the power off at the wall.
Hope this helps
Paul
Apr 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do we bypass the expired ink cartridge message on the HP D7360. Magenta ink cartridge is not empty.
Take out both the cartridges > wipe it with clean cloth> then the ink part of the cartridge wipe it with plain white paper> let little bit of the ink come out on the paper & put them back again in the printer>restart pc + printer - ur done. no more messages on your printer>then print a test page-simple.
Jul 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Printer
The cartridge needs cleaning. There are several things you can try. Using a wet paper towel, you can wipe the gold portion of the cartridge to try and draw out ink, or you can dunk the entire cartridge in warm water for a couple minutes or so (I have done this with success). The process is more clearly explained here:
http://www.usainkcartridges.com/faq.html
Jan 17, 2008 | Computers & Internet
288 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
