Question about Garmin StreetPilot i3 GPS Receiver
Can not get route information desoite having had it programmed into garmin
Despite the fact that i have dowloaded maps from the disk previously, this time fafter turning on, a screen appeared, saying"please use the provided PC software to load maps....".impossible to get rid of this screen, but Garmin still gives voice directions.The directions however were strange in that driving on the motorway, it directed us to turn right where the only possible exit was left!!!
  • 174 Answers
Try doing a hard reset. Hold down the back button (leftside), the thumbwheel, and then the power button. This will reset all setting back to factory default. You will lose any custom setting, recent find and waypoints.
Posted on Dec 31, 2007
Cannot unlock the maps in my garminedge 705. When i turn unit on message comes up cannot unlock maps
Information on unlocking garmin maps can be found at
There's more information there than you need since the article is about garmin nuvi satnavs that display a message "No detailed maps found that support routing" but part of the article deals with locked maps. The principle is the same for the garmin Edge but you'll need to skip to the part that deals with unlocking maps.
Jan 02, 2011 | Garmin Edge 705 Handheld GPS Receiver
"can't unlock maps" ????
Sounds like you have a Garmin and i don't use garmin, but it seems to me that i remember and keep running across the fact that you have to have a map key to use the maps and it sounds like this unit (if it is a garmin) has lost it's key, in which case you have to contact garmin to get the key and directions on how to install the key.
Or and you may get lucky on this, if you have the original CD disk you can reinstall the original software and this should install the key code as well unlock the units maps
May 30, 2010 | Garmin nuvi 1300 Car GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Unable to unlock new maps
Where did you download the Australian maps from? If from Garmin, contact Garmin for the unlock code. Maps have to be unlocked to a specific unit.
If you downloaded the maps from the internet, you will still need to contact Garmin for an unlock code.
Jun 14, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin GPS map 182: seems to work fine, but does not show navigational aids. Boat is tracked, and route is marked, plus previous routes shown. However, channel markers are not showing up. Any ideas?
Which channel markers? There is a settings menu for map detail, put that on highest (press menu once or twice to get to the setup menu)
Jun 16, 2008 | Garmin GPS
Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
59 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
