Compressor not working
Unit outside not running, tech replaced the start capacitator. when he turned on the power, a large bang occured.  He then said the compressor was gone.   Did he do something to cause this??  It is a Trane, 10 years old.
  • 334 Answers
Sounds to me like the compressor may be grounded, but i would check to see if there are any burn marks where he did his work. The compressor has an internal overload protection that opens and closes but may have failed. It is hard to tell what happened from here and who is to blame. A compressor can fail then end up blowing up afterwards though
Posted on Jul 18, 2009
What capacitors do i need to get to replace the ones on a 6 hp motor
Due to the nature of power factor correction and other sizing criteria it is best to open the can on the motor that protects the capacitor and order a comparable unit for capacitance, number of sections (- ie, start/run versus Start or Run) plus capacity and working volts AC. Unless ordering from the original compressor supply company, most parts houses will not have a cross reference with that data.
Jan 31, 2012 | AO Smith 6 Hp 3450rpm R56Y Frame 230 Volts...
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
Outside fan want start by itself and tries to do mo
Sounds like your condenser (outside fan) is inoperative.
It is essential that you make sure this motor is operating as it should. I would look on the motor for a place to 'oil the bearings,' (if you are lucky yours will have oil ports where you can oil them) but most new motors (these days) do not have these (oil ports) - however - if you are fairly adept at mechanical stuff - you can read my 'tip' on - "how to oil a motor when there is no place to oil it," and possibly get it to running properly again.
If you are unable to do so (by oiling the bearings) - you only recourse is to replace it. Again, if you are so inclined - replacing a condenser motor is not that difficult. The most important thing is to get the exact motor to replace it with. I would try to find someone - a friend or relative that is knowledgeable in Air Conditioners - to look at your unit and who wouldn't mind picking up what you need at a Air Conditioning Supply house for a wholesale price.
If you can't do that - then you will have to take your motor off - be sure all power is off before you remove it - and be sure you mark all the wires 'exactly' so that you can wire up the new motor. Note: the most difficult part of removing the motor will likely be getting the fan blade off the shaft of the motor - so if it's really rusty/dirty looking/or even if it isn't - I would first remove the set screw holding the hub on the shaft - and really 'spray the hub of the blade/shaft of the motor' with WD-40 - really good - trying to get the WD 40 on as much on the shaft as possible - fill up the hole where the screw was - soak it well and let it sit for awhile - preferably several hours. After letting it sit - use a hammer to "tap" it (lightly/medium hard) to loosen the shaft on the hub - and take a wrench (crescent wrench) and turn the shaft - it shouldn't be a problem to get off.
After removing the motor- Note: I would also replace the capaciter (the little gray/silver component that is attached (by wires) to the motor) and marking the wires - you will need to take both motor and capaciter to an Air Conditioning Supply house (that sells to the public) and buy 'exact' replacements. Note: it's possible though not likely that the capaciter could be causing the motor not to run (after oiling the bearings) - but unless the capaciter is bulged - I would figure it's good and not causing the problem - although I would still put a new one on - with a new motor. If you suspect the capaciter is bad for whatever reason or just want to try it - you can always replace it with a new one and see what happens.
Note: you will probably be charged 'retail' instead of 'wholesale' - for the motor and capaciter - but the price difference shouldn't be that much - I would estimate no more than $125 for the motor and capaciter. Be sure when you put the new motor/capaciter back on the unit - that all power is off - and that you put motor and capaciter back on exactly the way the old ones were. Be sure you note the "position" of the blade on the shaft of the old motor and position the blade on the new motor in the approximate same place.
If you prefer to have a Service Tech do this - you're looking at a Repair bill of around $375 and up - and bear in mind - whether you do it yourself or have someone do it for you - "there may be another problem" going on with your unit, i.e. low on charge or something, so as so often happens in life - your 'best and cheapest' way out may be to call a Service Tech from the git-go.
hope this is helpful
good luck!
Jul 26, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a Rheem Clasic 10 SEER air conditioner, the outside unit works but no cold air
Is the compressor running or is just the fan running. If the compressor is running you should hear it humming.
Aug 28, 2009 | Computers & Internet
Amana AC model MBR2000, installed mid May 2009. When outside temp gets above a certain level the AC does not cool. fan keeps running and it keeps trying but not work. When outside air gets cooler then...
Hi it sounds to me like what actvates the 2nd stage of the compressor is not turning the compressor on when the ambeint temiture reaches the point that it calls for the 2nd stage to start it may be an out door thermostat or a ambient senser and I would request a new Tec to come out and ckeck
Aug 24, 2009 | Heating & Cooling
New outside compressor 4 ton Ruud 13 seer unit.
Sounds like a compressor needs to be replaced. You will need a service tech to make sure of it. Sometimes the compressor can work for a long time that way. Check your warranty. Usually compressors will have longer warranty on it.
Jul 25, 2009 | Heating & Cooling
This is about a 15 YEAR OLD Trane XE1000 30,000 BTU A/C unit. The A/C was not working, but right after I called to have someone come fix it, it started working again all by itself. When the unit was not...
You can wait just buy a capaciter start system theat will override the old start capaciter, this is a common problem for all ac systems. just bu the ac start replacement and yo should be good to go for a couple more years. and if you want a reference page let me know where and I will give it to you.
Jul 20, 2009 | Heating & Cooling
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Fan in my Central Cooling Conditioner Unit are not running
NEVER POKE AT ANY PRODUCT on a heating and cooling system it need to be serviced by a trained tech that knows what is going on in the unit, poking around can cause death and at the least a large sum of money if you poke the wrong place
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
