Question about Lynx Aurora 8 and 16: Aurora 16 Sound Card
9-16 channels issue
Setup: mac - aurora lynx 1-16 connected via accel card - option card primary port, mac - rosetta 800 connected via accel card - option card primary port. clock source is big ben. software platform: protools
1) how must the power up sequencing to enable lynx as 1-8,9-16 i/o & rosetta 800 as 17-24 i/o?
2) MY 9-16 channels are not working well. they dont have any output. sometimes the meter is all cool but no output going to protools.
i,ve used this for a few sessions already but now is pretty unstable
  • 3 Answers
So you have your core card and how many accel cards?  Which interface is plugged into your core card? If you want the lynx to be 1-16 in and out the easiest thing to do is to make sure it is plugged in to the core card and your rosetta is plugged into the accel card installed after the core card.  As far as I know the power sequence won't change the assignment of the i/o.  If you don't want to change where the interfaces are plugged in then you can do it in the i/o setup and save the setup for the way your interfaces are plugged into the computer.  If your already plugged into the computer like I said then you will need to check the i/o setup to make sure the i/o setup isn't all scrambled.
Posted on Apr 26, 2009
I need the activation codes for rosetta stone Latin America Version 3. I think I have the 2007 Rosetta stone program set up.
You will find the activation code inside the box on a small card, If you don't find it contact Rosetta Stone with your Order number to get new one.
Questions Rosetta Stone Community
Dec 09, 2014 | Rosetta Stone V3 Spanish (Latin America)...
Rosetta stone error code 3217
You should contact Rosetta Stone's customer support directly. They are excellent in helping with your computer issues. Phone number is 800-280-8172.
Sep 25, 2012 | Rosetta Stone Spanish (Latin American) -...
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
Microphone will not pass setup
I have finally found a solution! I found it by chance on the rosetta stone troubleshooting page. I have nod 3 antivirus + firewall and in the firewall settings the rosetta stone application was blocked (it was denied internet access). I just deleted it from the list and the next time rosetta stone asked for internet access I clicked yes. Now rosetta stone detects both my dynamic microphone and my usb headset and it works fine. Hope this works for everybody.
Jun 21, 2009 | Rosetta Stone Spanish (Latin American) -...
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(INT 0 (IRQ 5 (MODE +E)))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
May 23, 2009 | Creative Labs CT4170 Sound Card
I tripped and ripped headset cord out of usb port leaving plug in
I don't need assistance like your Premium Plan! I need to find a replacement for my headset specific for the Rosetta Stone program.
Mar 22, 2009 | Rosetta Stone Italian Level I and II...
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Lynx Aurora 8 and 16: Aurora 16 Sound Card Logo
144 people viewed this question
Top Lynx Computers & Internet Experts
David Payne
David Payne
Are you a Lynx Computer and Internet Expert? Answer questions, earn points and help others
