Question about ViewSonic VX2235wm LCD Monitor
VX2235 LCD display
Can i and how do i connect display to get T.V. or watch d.v.d
  • 63 Answers
Unless you're hooking a computer up to the monitor and watching TV/DVDs on the computer, you need a TV box such as this: http://www.kworld.com.tw/product_overview.aspx?P_ID=15 in order to watch TV/DVDs on your monitor.
Regards,
Javabytes
Posted on Nov 19, 2007
Hello,I am currently using a Viewsonic VX2235 monitor. When I turn on the PC the monitor stays black and it takes turning the monitor on and off several times to get it to work. Would greatly appreciate...
The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | ViewSonic VX2235wm LCD Monitor
My digits are dimming or fading making the watch hard to read. Battery reading is "high"
mcdevito75 Here, The battery could be loose makeing a weak connection or the LCD screen could be going bad, Have a small watch repair shop in your area check it out. If you can do so yourself be very carefull as too much pressure on the battery (PRESSING) could destroy the LCD face of the watch, also if the display (FACE) of your Casio ever goes black, even if display returns, the LCD is going bad.
Feb 05, 2011 | Casio G-Shock GW700A-1V Wrist Watch
I bough the LCD model VA2231w- LED every time I turn it on then it pop up that change the resoluyion to 1920/ 1080P I don't know how to do it. So please help. Thanks Thai Nguyen
This would be the Native resolution. That your display functions and displays best in.
Windows XP, Vista and Windows 7.
(1) RIGHT mouse click over your desktop.
Windows XP will differ - but same basic idea to navigate and make this fix.
Pictures show from a Windows Vista Machine (extremely similar to Windows 7)
(2) Click Display settings
(3) Now you'll see a slider bar, Native Computer Display 1680x1050 resolution.
Some computers can not support this resolution and may cause non operational situations.
If the display setting is not on the slider bar. Chances would be that it's not a supported Resolution.
"Older computer" If the display doesn't show while trying different resolutions - do not click apply and wait. the screen will return to it's previous setting. ViewSonic VX2235 has a Setting that could be used to Disable this annoying message - Revert to ViewSonic lightdark_2.jpg
Nov 15, 2010 | ViewSonic VX2235WM Monitor
No display
Look for bad caps as shown in the VX2235 album.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed Viewsonic Monitors pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 28, 2010 | ViewSonic VX2235wm LCD Monitor
My Viewsonic 2235wm goes on and off frequently
Look for bad caps as shown in my VX2235 album.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 25, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
Hello my vx2235 lcd display is not loading,the screen has on it, out of range H. frequency 95KHZ v. frequency 60KHZ the buttons on the screen dont do...
This monitor and all other have known problem with power supply DC filter caps.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Look for that first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Aug 11, 2010 | ViewSonic VX2235WM Monitor
My monitor viewsonic vx2235 wm model VS11349 has not picture. Power but no picture. Can you help me figure out what's wrong? Thanks
Hi the problem from the power board . If you are comfortable with soldering all you have to do is open up your monitor ,remove cables connected to power board. Make a sketch of what it looks like noting the location of the capacitors and thier rating . All you have to do is replace them with ones of the same rating and couple them back. The ratings would look like this 10uf/25v it's better to find exact match or if you have 220uf/25v ,you can replace with 220uf/35v.
Jul 28, 2010 | ViewSonic VX2235wm LCD Monitor
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
113 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
